20 Most Recent Samsung CLX-3305FW Color Laser Multifunction Printer Questions & Answers
remove all toners and on the left hand side is the waste ink container. You should be able to simply remove. and yes you will have to order a new one, or try and empty that one
Samsung... | Answered on Nov 18, 2015
1st don't wear a new shirt when doing this !!!!
waste toner tanks are not meant to be reused (not saying you couldn't ) but its gonna make a mess doing it so id choose not to do iinside the office that's for sure , replacement tanks are available from same sources you buy toner cartridges from then just tape up the spout and toss old one away , some machines will require a manual reset of toner tank alarm , consult your manual to see how you do it
and if your dead set on cleaning it , what id do is buy one new one install it and take old one outside in a field miles from nowhere using 91% isopropanol alcohol and a hand full of old rags (disposable gloves too) id wipe it clean ,then store it under machine in paper storage box (not tray) so its there ready to use next time you need it
Samsung... | Answered on Sep 17, 2015
Dear Barati
The printer may have some error. pl. check on the display of the printer. After clearing the error the received fax will printed.
Thanks.
Samsung... | Answered on Mar 17, 2015
Insufficient information to answer the problem. Try going directly to their web site http://www.samsung.com/us/search/espsearch.us?keyword=CLX-3305FW+ and check the SUPPORT and FREQUENTLY ASKED QUESTIONS section
Samsung... | Answered on May 04, 2014
Go to System Preferences--> Print & Fax-->Under Printers click the + button and add the printer to your queue
Samsung... | Answered on Aug 04, 2013
The Brother AX10 ribbon should fit it I have them
Office Equipment... | Answered 4 hours ago
Samsung CLX-3305FW Color Laser Multifunction Printer Logo
11 questions posted
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
connect printer imac
  • Office Equipment & Supplies
