20 Most Recent Kenneth Cole KC3434 Wrist Watch Questions & Answers
you might need tool to open caseback.
Kenneth Cole... | Answered on Nov 26, 2014
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Kenneth Cole... | Answered on Aug 17, 2010
Take the watch to a jeweler for a demonstration.
Kenneth Cole... | Answered on May 13, 2019
Ive heard people say many times to put cell phones in a bowl of dry white rice to remove moisture from them,so Im sure it would work for a watch as well. Just make sure to leave the watch in the rice over night,and make sure to have none of the watch showing in the rice---it will need to pull moisture from within the tiny parts.
Kenneth Cole... | Answered on Feb 18, 2019
Maybe a reset button inside marked a.c. if so short it between battery and a.c. button.
hope this helps
Kenneth Cole... | Answered on Dec 21, 2018
Type, not size. Take your Kenneth Cole watch to a jeweler who will open it and identify type.
Kenneth Cole... | Answered on Nov 19, 2018
Try Googling (Kenneth Cole)(kc8041)(manual) without parens.
Kenneth Cole... | Answered on Mar 17, 2018
Try Googling (Kenneth Cole)(UL 1197 S 60)(manual) without parens.
Kenneth Cole... | Answered on Feb 10, 2018
Kenneth Cole KC3434 Wrist Watch Logo
2 questions posted
Top Kenneth Cole Watches Experts
Arturs Kalnins
Arturs Kalnins
Gary Nitowski
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Kenneth Cole Watches
Most Popular Question
open back
  • Watches
