20 Most Recent Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Questions & Answers
This is probably one of the best videos I have ever found on replacing auger motors...at least how to access them in Kenmore units. I hope this helps you with your issue.
Kenmore 55612 /... | Answered on Nov 28, 2017
NO WARRANTY . try BAKING SODA
Kenmore 55612 /... | Answered on Sep 25, 2017
Probably leaking refrigerant.
Kenmore 55612 /... | Answered on Sep 01, 2017
Hello Murr9,
The number 1 reason a freezer "SEEMS" to be working... but the refrigerator isn't cutting it... is PROPER AIR FLOW...
look through the vents in the back of the freezer section...
If you see thick frost or ice... you have found your trouble
If the evaporator fan (behind the freezer wall is operating at ANY speed your REFRIGERATOR section would be adequate...
You had a repair person out... but
while that ought to mean something to me... I would rather
you do some simple checks...
- Look through those vents
- You need to check the defrost pan... DRY means you have
troubles... put a piece of fresh typing paper inside the pan...
fold it over the edge... if it is still dry the next day...
Your defrost circuit is broken...
It only has three components:
- heater element
- defrost thermostat (opens at room temperature)
- Printed Circuit Board
Your refrigerator DOES NOT have a defrost timer... but rather a PC Board...
($152, see below... plus how to video)...
Most expensive part but easiest to replace...
Important - Important - Important
TAKE PICTRES OF ALL THE WIRE
connections BEFORE you start.
http://www.appliancepartspros.com/whirlpool-timer-defrost-4388932-ap3109394.html
Get on AMAZON and buy yourself a couple of the TAYLOR REFRIGERATOR thermometers...
zero Fahrenheit is fine for the FREEZER...
REFRIG should be just above 32 degrees
Fahrenheit...
Amazon com Taylor Freezr Refrig Thermometer 1 pack of 3 items Home Kitchen
partsselect
PartSelect Appliance Parts and Repair Help
repair clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Kenmore 55612 /... | Answered on Mar 04, 2017
Please type the site "Sears Parts Direct "into your search engine, and you will get a website with a phone number you can call for help, they should have that answer for you.
God bless your efforts.
Kenmore 55612 /... | Answered on May 02, 2016
Yep, if the engineer had worked for me, I would have fired him/her. I have gone through 3 of them of the past 3-1/2 years until I got tired of it.
That said, it likely brakes at the same corner/corner. You will likely find a cavity inside each broken half. Using superglue and a small flat piece of metal (cut from a metal washer) sized/formed to fit inside cavities when the broken half are pieced together. Trial piecing the pieces together first before glueing them together.
If there are no cavities (solid), try creating one (you may be able to drill/carve out) in each broken half then follow the steps above.
Guaranty better than new and last a whale of a lot longr.
Good luck.
Kenmore 55612 /... | Answered on Apr 25, 2016
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
1,480 questions posted
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Refrigerators
Most Popular Question
kenmore side side icemaker bin door
  • Refrigerators
