20 Most Recent Apple iPad Mini Questions & Answers
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Apple iPad Mini | Answered on Jul 15, 2019
There are several solutions to solve your problems. First you can try the default passcode 1234. But if you surely forgot 4 digit password, you have to restore the password. And below steps can help you.
1. Run the latest version of iTunes on your computer and then make sure that you do not connect your iPad with your computer.
2. For iPad with Face ID, you need to press and hold the top button or the volume button till you see the slider of power off shows up on the screen. Drag the slider from left to right to turn off your iPad. After that, plug your iPad into computer while holding the top button. You need to hold it until the recovery-mode screen appears.
For iPad with home button, you need to press and hold the slide or top button till you see the power off slider interface. Drag the slider from left to right to turn off your iPad. Afterwards, you need to insert your iPad into computer with proper USB cable while holding the home button. You need to hold the button until the recovery-mode screen displays.
3. In the interface of iTunes, you will see a dialogue for you to restore or update, you need to choose the option of "Restore" in the panel. Thus, iTunes will download program for your iPad. You need to wait for over 15 minutes until your iPad exit the recovery mode. Thus, you need to repeat steps 2-4.
4. Wait for the end of the procedure to set up and use your iPad without a passcode.
The process to remove iPad passcode via restoring iPad with iTunes is not so hard for you at all. You can give it a go to help you to pass through the passcode inquiry simply.
For more methods, check: Remove iPad Passcode through Restoring iPad with iTunes
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Apple iPad Mini | Answered on Jul 04, 2019
If the important contacts in iPad get deleted, you will try to get them back. Restoring iPad with the iTunes backup is the easiest way to recover deleted contacts on iPad mini. If you update your iPhone backups regularly, then you can recover most of the important data from the backup. The restoring process is also easy to be done, and the following tutorial is for the new users of iOS devices:
  1. Connect iPad mini to computer with USB cable, and iTunes will launch automatically. If not, you should manually start iTunes.
  2. iTunes will recognize iPhone and display the iPad icon at the upper left corner. Click the iPad icon.
  3. The control panel of iPhone appears after you click the iPad icon. Click Summary in the panel.
  4. Click Restore Backup in the right part of the window. Then iTunes will allow you to choose the iPad backup, and finish the restore.
Visit here to know more methods about iPad contact recovery.
http://www.leawo.org/tutorial/how-to-recover-deleted-contacts-on-iphone-6.html
Apple iPad Mini | Answered on Mar 31, 2019
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
Apple iPad Mini | Answered on Nov 01, 2018
Connect it to a computer with iTunes. Set up your own Apple ID and Password. Then Reset the iPad.
You can also do it from the iPad itself Settings - General and at the very bottom command RESET.
After the reset you will be able to set it up from new.
Please note that the RESET command clears EVERYTHING off the device.
Apple iPad Mini | Answered on May 03, 2018
If you've got a headphone plugged into the headphone jack remove it. If this issue is (still) there without a headphone plugged in and you have no bluetooth headphone paired (disable Bluetooth to test) then i suggests the headphone jack is faulty. You might have a look if there's dirt and/or dust inside the hole. Carefully try to remove it using a toothpick. Use no needles, no liquids and similar for this.
If the problem disappears with bluetooth disabled check the bluetooth gear.
Apple iPad Mini | Answered on Apr 16, 2018
I've never experienced the Camera app to disappear, but since you can't get any output off the camera even with third party apps i suggest your iPad camera might be broken. It could be that the native camera app is only available when iOS detects a camera. Since the app is gone i presume both cameras are no longer connected to the base board. Did you have a screen or battery replacement lately? Then go back there and have them fix this because most likely they did not (properly) reconnect the camera.
If your iPod won't turn on, click here:
iPod won turn on
Apple iPad Mini | Answered on Apr 06, 2018
First check that your iPad is connected to the internet in the settings, and to see if it is connected to your WiFi. check in the App Store if there is an update available for Ice Age Village, and if there is, then you can update through the App store. If that does not work, I suggest saving your game data through the Game Center and re-installing the app.
Apple iPad Mini | Answered on Mar 29, 2018
When you get a router, it would usually come with a password, automatically locking the WiFi for added protection. You can find the password on the router. Since you said that putting the password makes no difference, it could be because the password was not input correctly, where you have to put the exact capitalization of a letter.
you will need to update your software
Apple iPad Mini | Answered on Mar 15, 2018
Apple being a well-known company has earned their brand name by creating various devices, which they have been introducing to the public in an innovative method. All their products are known for their excellence in terms of every aspect. Any machine needs a repair and troubleshoot at times, in order to make the users experience the best out of them. This is where the need for Apple Technical Support Number 1-833-493-0111 rises up.
We do offer the below mentioned Apple product support services that include any kind of Mac Series:
    ·MacBook Air Support
    ·MacBook Pro Support
    ·MacBook Support
    ·Mac Mini Support
    ·Apple Mac OS X Support
    ·iMac Support
    ·iPad Support
    ·iPhone Support
    ·And other support with associated software's for your devices. All the above mentioned Mac versions do have their own design and setting, and every other device is completely advanced when compared to one another. The iMac has various new features with the latest updates, like the track-pad and magic mouse, which tend to provide an amazing user experience. The technical assistance experts work round the clock in resolving any kind of issues that face with your Apple device.
1 833 493 0111 Apple Mac Technical Support Phone Number
Apple iPad Mini | Answered on Jan 16, 2018
When you click n contacts a list of all contacts should display and you can scroll down til you see the name of the person you need. If you need to change any info select edit and change.
Apple iPad Mini | Answered on Oct 16, 2017
icloud locked is a personal security code not apples and apple will not be able to help you what you bought is a parts ipad
Apple iPad Mini | Answered on Apr 10, 2017
try to play it on another device the app could be corrupt
Apple iPad Mini | Answered on Feb 13, 2017
Apple iPad Mini Logo
528 questions posted
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
forgot password mini ipad find password
  • Tablets & eReaders
