20 Most Recent Mitsubishi WD-62526 Projection TV Questions & Answers
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Mitsubishi... | Answered on Dec 13, 2013
Video board malfunctioning....Get a honest TV tech. Only three years old? It is worth repairing, will deliver several more years of excellent service. A quality television.
Mitsubishi... | Answered on Nov 14, 2013
TRY GOING IN MENU AND AJUSTING PIC QUALITY
INCREASE THE BRIGHTNESS , IF YOU CAN
Mitsubishi... | Answered on Nov 10, 2013
your tv has become to sensitive. could be threw the electric supply or the infrared board. if it is electric you will need to find the appliance that when it use the consumption more. you can use an old analog radio and go round the house with it out of signal listening for buzzing sound. sometimes it is the fuse box or a wire in the wall some were.failing that just change the inferred board and hope for the best but it will come back if there is and electrical fault. had this a few weeks ago in a friends house turnd out to be the fuse breaker changed it and it was fine even his phone works better now as well.
Mitsubishi... | Answered on Oct 23, 2013
Very common in these sets and two things for YOU to look for.
1. Remove lamp and inspect the 2 pin socket it engages--very easy to if installing a lamp bend the socket a little out of position and lamp does not go in correctly---from the inside rear two small screws hold that socket in position--in this case what I do is loose or remove the screws, insert the lamp and then put the socket to the lamp and replace the two screws, that way you know its on right and is lined up correctly.
Frankly, the socket is way to flimsy and this happens a lot.
Second and less likely there may be a lot of dust on fans etc inside, have had to use a compressor and dust out more than one of these sets (if do that, do it outside as it may look like a dust storm).
Mitsubishi... | Answered on Dec 26, 2012
If you cannot find it I doubt you will be able to replace the parts but I seem to recall seeing a video or two on U Tube about this.
Mitsubishi... | Answered on Jun 17, 2012
Almost any code for Mitsubishi sets will work but if not an original remote for the set have limited features with it.
Mitsubishi... | Answered on Jun 12, 2012
Almost any code for any mitsubishi set made over the last 15 years or more should work--if not a original remote being used it may have only some features needed.
You clearly could have a audio problem in the set but:
Look in set menu to see if speakers are turned ON or OFF.
Look at set and a cable,sat box or receiver to see if sound is turned low or muted etc.
See if set has sound when a DVD etc is imputed to the rear audio/video jacks--if it works that way the set is good and you have a problem with settings somewhere.
A last resort is most of the Mitsubishi sets have a hard reset done by entering a hidden menu with the remote--sets everything back to factory original.
Mitsubishi... | Answered on Apr 30, 2012
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Mitsubishi... | Answered on Nov 16, 2011
Mitsubishi WD-62526 Projection TV Logo
63 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
replaced lamp now tv want come lamp
  • Televison & Video
