20 Most Recent Bosch Axxis+ WFR 2460 Front Load Washer Questions & Answers
the pump cap goes back into the machine about 7 cm (3 inches). It has openings that allow the water from the tank to drain during normal operation. However, if something (like a hairpin) is long enough to lodge between the cap's hole and the drainage tube then when you try to twist the cap open it jams against the offending item (hard to explain without a diagram). The only way to remove it is to tip machine up, unscrew whole pump unit, undo clips holing it in place and then pulling rubbish out. It's a pain. Then make sure the propeller is back in place, securely (or this will lead to more noise and refixing - which will be easier 'cos at least you can get the @#$#$% cap off now).
Bosch Axxis+ WFR... | Answered on Oct 26, 2018
Check the drain pump
Bosch Axxis+ WFR... | Answered on Dec 15, 2017
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
Bosch Axxis+ WFR... | Answered on Aug 04, 2017
Does the tub turn at all when you start it?
Sam
Melbourne Domestic Appliances
Text 0424395512
Bosch Axxis+ WFR... | Answered on Apr 08, 2017
Hello, Welcome to fixya.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly and a short testimony is also appreciated.
Thank you for visiting "fixya" for your washer solution inquiry and good luck going forward.
Regards,
Macmarkus :)
Bosch Axxis+ WFR... | Answered on Mar 14, 2015
Is the belt wore out and slipping? Check this first.
Bosch Axxis+ WFR... | Answered on Sep 09, 2014
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Bosch Axxis+ WFR... | Answered on Jul 15, 2014
Check your solenoid valves if the coils are healthy.
Bosch Axxis+ WFR... | Answered on Nov 27, 2013
Bosch Maxx This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Bosch Axxis+ WFR... | Answered on Aug 05, 2013
Bosch Axxis+ WFR 2460 Front Load Washer Logo
125 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
pump blocked cannot open remove cap
  • Washing Machines
