20 Most Recent Fleck 165,000 Grain Series 2850 Commercial Water Softener 1700 Brine System w/Brine Valve Questions & Answers
How old is the system ? Where does the system drain to ? If this is the softener you have (seems awful large for a household) it is probably the injector/nozzle assembly. I have attached a manual to help you. A restriction in the drain line could also be the problem. Fleck 2850s
Fleck 165,000... | Answered on Mar 28, 2014
If you're getting salty water from a reverse osmosis permeate line, that means the ro membrane is ruptured or the membrane o-ring is deformed.
Replace the o-ring and if that does not solve the problem, replace the membrane as well.
Fleck Water... | Answered on Mar 22, 2018
Eductor assembly is most likely plugged with iron. Clean thoroughly. Make sure the salt is not mushed and packed in bottom of salt tank also.
Fleck Water... | Answered on May 01, 2014
It may be time to replace the light or the Light ballast.
To reset the CHANGE FILTER indicator light, press and hold the LOCK and LIGHTkeypads until the CHANGE FILTER light blinks (approximately 3 seconds). The control for the light is now reset for another 12 months or 416 gallons of use.
Water Dispensing... | Answered on Sep 13, 2019
It screws on to the tank. Make sure to relieve water psi. Turn the water off first.
It is common for it to have high PH after replacing filters. It will adjust after the first 15 to 20 gallons. When I replace filters 10.8ppm to 11.2ppm is normal. After so many gallons I read 9.6ppm https://www.freedrinkingwater.com/faq.htm
Water Dispensing... | Answered on Apr 02, 2019
Fleck 165,000 Grain Series 2850 Commercial Water Softener 1700 Brine System w/Brine Valve Logo
1 questions posted
Top Fleck Water Dispensing & Filtration Experts
ray gallant
ray gallant
Larry
Tom Chichester
Are you a Fleck Water Dispensing and Filtration Expert? Answer questions, earn points and help others
View Most Popular
  • Fleck Water Dispensing & Filtration
Most Popular Question
water softener full water not draining
  • Water Dispensing & Filtration
