20 Most Recent Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV Questions & Answers
Yes, can use a damp cloth to clean. spray the water on cloth never to the screen.
Sony Bravia... | Answered on Jan 10, 2019
Hi
at HDMI may be some signals are disturbing the tv at BBC1 so please try to change the HDMI setting if the problem goes then ok other wise you may connect your tv box through AV
Sony Bravia... | Answered on May 10, 2016
This is the main fault, that most Sony LCD TVs. The actual cause is with a faulty T'Con board. For most Sony LCD sets, this part [T'Con board]; will be a built in part with its display panel, and can't be replaced. Display panel replacement is the only repair work. Nothing can be done, even for the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Sony Bravia... | Answered on Mar 04, 2016
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sony Bravia... | Answered on Jul 09, 2015
Hello Mate
Is your KLV-32U300A have PCMCIA Card so you can connects easily your BT Tv. but if your TV don`t have that slot so sorry dear you have to upgrade your Tv. And I am surpizse that model is almost 4 to 5 years old, And its still works. (Nop its don`t have the PCMCIA CARD SLTS). Share with me you BT TV model or Device #.
Sony Bravia... | Answered on Dec 11, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sony Bravia... | Answered on Oct 30, 2014
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Sony Bravia... | Answered on Aug 11, 2014
Replace either Tcon Board or LCD Panel for this problem
Sony Bravia... | Answered on Nov 24, 2013
you might want to start with the t-con board. it can cause green colors missing
Sony Bravia... | Answered on Nov 11, 2013
change your sound option and try again
Sony Bravia... | Answered on Oct 13, 2013
Sony Bravia KLV-32U300A 32 in. HD-Ready LCD TV Logo
77 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
fingerprints screen use damp cloth
  • Televison & Video
