20 Most Recent GE (PSS26MSRSS) Side by Side Refrigerator Questions & Answers
Hi, Check and see if the gasket is leaking any where. Also check and see if the door to you ice dispenser is closing. Ice/frost only builds up around the door hen there is an air leak.
I hope this helps you. Please let me know if I can assist you further,
Thanks
Vic
GE (PSS26MSRSS)... | Answered on Aug 11, 2018
clean you condenser coils
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
GE (PSS26MSRSS)... | Answered on Jul 01, 2018
There is a thermostat on evaporator,that's not working
Try YouTube or repiar clinic for more information.
GE (PSS26MSRSS)... | Answered on Mar 07, 2018
It sounds like the cirulating fan between the freezer and the fridge is not operating. I have been successful in lubricating the bearings. It may need replacing. Available online
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
GE (PSS26MSRSS)... | Answered on Mar 03, 2018
Yes the double element will work. It is the new replacement part.
GE (PSS26MSRSS)... | Answered on Feb 09, 2018
If your ice maker is working your filter is fine. You need to check the solenoid valve that feeds the water dispenser. You should have 2 of them on the water line. One that feeds ice maker and one that feeds the water dispenser. That is most likely your problem
GE (PSS26MSRSS)... | Answered on Jan 21, 2018
sounds like you have a defrost problem,this is common,most likely you have a bad thermistor located on top of the evaporator coil,it's part wr55x10025,it looks like a white bullet,if you look at it and if it has a black ring around it where the wires connect to the bullet looking part these sensors or thermistor had problems and should be changed out,or you have a bad defrost heater part WR51X10101.you can check the heater for continuity with a meter or just look at the element in the glass of the heater,if it's all black looking replace it and the thermistor and you should be fine as long as you don't have a mother board problem but the heaters and thermistors do fail,so unplug the fridge or shut the breaker off so you don't have to pull out the fridge,remove the food from the freezer,get a hair dryer and melt off any ice on the back wall that's in your way,then remove the back inside wall of the freezer,get a towel and stick it under the coil and on the freezer floor,melt out all the ice with the hair dryer,if you don't use towels inside and you melt all the ice the pan will overflow onto the floor so you want to catch the water in towels,after you melt out the ice remove the heater two screws and look at it and check it with meter,if it looks black inside the glass replace it even if it reads good with meter,then cut out the thermistor on the top of coil,the new thermistor is just the bullet and two wires coming off of it,cut the old one out and leave enough room so you can connect the new one you have to buy some plastic nuts to connect each wire with,when you crimp the nuts or you can use regular wire nuts,but i use silicone sealer and cover the opening where the wires go into the nut or cap whatever you want to call them just so no water gets in there,the best way is say you cut 6 inches off of the wires on the old part try to leave the new part almost the same length or a little longer but it doesn't matter if it's not exact,this is used instead of thermostat because you have a mother board in this machine,there is also a t-stat on top of coil but not used like older machines so change out the thermistor and heater and you should be fine,put everything back the same way.one more thing that should be done at least once a year is pull out the fridge from the wall,remove the bottom back panel and clean out the condenser coil and back wall cover,i use a shop vac i vac off the coil and then set the vac up to blow and blow the coil out,this is the best way to clean this coil,it's round and hard to clean,.if you still have an issue the only thing left is the mother board but this part costs some bucks change out the parts i told you and most of the time it's not the board.hope this helps you out.one more thing make sure the evap fan is running and that ain't bad,just open the freezer door,you should hear the fan blowing in the freezer,that's the easiest way to check the fan motor.
GE (PSS26MSRSS)... | Answered on Jan 14, 2018
i assume you leaking from the connections?
GE (PSS26MSRSS)... | Answered on Jan 11, 2018
Lean it back slightly and the door will close itself.
GE (PSS26MSRSS)... | Answered on Jan 07, 2018
It should just pull right off. Try downloading a manual from the makers website.
GE (PSS26MSRSS)... | Answered on Dec 15, 2017
Defrost heater and thermostat is located behind inside back freezer panel. That panel has to be removed.
GE (PSS26MSRSS)... | Answered on Dec 06, 2017
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
GE (PSS26MSRSS)... | Answered on Nov 21, 2017
In this case just call the Service.
It's stocked just betwen Icemaker and Wather...
Better call them...
GE (PSS26MSRSS)... | Answered on Nov 14, 2017
Look for the information label inside the refrigerator side usually near the top of the box. It will have the model number and date of manufacture on it.
GE (PSS26MSRSS)... | Answered on Oct 30, 2017
GE (PSS26MSRSS) Side by Side Refrigerator Logo
3,776 questions posted
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
freezer sound like cessna when fan goes
  • Refrigerators
