20 Most Recent Brother PED Basic Card Writer Box & Embroidery Magic II for PC Questions & Answers
Go to the website and find your product to download a driver: PED Basic United States Brother Solutions Center
Brother PED... | Answered on Apr 15, 2014
The PED-Basic should only be installed with the driver and the software from Brother: http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/dlfh/000000/000100/dlfh000107.html?reg=us&c=us&lang=en&prod=hf_basiceus&type2=47&os=99&flang=91&dlid=dlfh000107 .
Since you've attempted to install the software from another source, you may have the product partially installed in the Windows registry. This could block a new installation. You can try to uninstall the product with Revo Uninstaller: http://www.revouninstaller.com/revo_uninstaller_free_download.html .
Otherwise, you will need to go through the registry and delete lines related to PED Basic. Make sure to back up the registry before searching it. Start > type regedit into the search box. Then File > Export (choose all and back up to a location other than the c: drive).
Embroidery Magic 2 is not compatible with Vista (or Windows 7). For more information, try contacting the creators via the contact at: http://www.auntymdesigns.com/html/software.html . The work-around is to use the software is a second machine with an older version of Windows. This can be a real computer, a dual boot computer or a virtual computer. For most of these you need a valid (licensed version) of the older Windows OS and the virtual computer program (for the last option). The exception is that Virtual PC and XP mode can be installed for free on computers running Win7 Pro or Ultimate. For a virtual computer, you will not be able to have the PED Basic hardware available to both the real and virtual computer. It can be installed on one or the other. Also files can't be shared directly between the real and virtual computer. They need to be saved to external media (optical media or external drive).
However, the installation of the software or hardware in a virtual computer is the same as any software install on a real computer.
I hope this helps.
(alternatively, you can upgrade your software. See the auntymdesigns site above.)
Brother PED... | Answered on Jan 04, 2011
I've just had the same problem and found that you need to change the size of your hoop down to a smaller hoop size. Hope that works for you!
Brother PED... | Answered on Sep 05, 2010
HI irenepaine. I've installed this once and I know it could be a little tricky because you need to use the software to convert whatever design you want - from JPEG to the machine's type. Then you use the card to save the file and then connect it to the sewing machine and then, using the display select the file you want. You need to use like 2 different software to acomplish this. Also you can do it thru the USB cable. Since I can't remember - I'm sending you the brother support site. Please find the correct model and see if it helps.
http://welcome.solutions.brother.com/bsc/public/Model_list.aspx?reg=us&c=us&lang=en&titleid=36#pe
Please dont forget to rate and provide positive feedback for our free support today. Thank you :D
Brother PED... | Answered on Apr 29, 2010
the card may be bad or damage or the card reader is bad or it is damage
Brother PED... | Answered on Apr 24, 2010
it sounds like you may have a driver problem and possible the installation was not done properly. I would say. uninstall whatever you download and start from scratch as follows:
if you DO NOT have vista or windows 7 do this follow the instructions to install the sofware from the the manual
if you need to download the sofware in case you don't have the cd you can download the updated sofware from here
if you DO HAVE vista or windows 7 you need to download the software package from this page just go to the bottom and you'll see section for your operating system
Brother PED... | Answered on Jan 16, 2010
right click on icon click properties and set to xp
Brother PED... | Answered on Jan 07, 2010
Hi.
Try using a different card. If the card is damaged it may not be read in the sewing machine.
Also , the card should be compatible with Babylock, but give them a call just to ensure there is no particular issue with this model. you find their number on the Babylock owner manual.
If the design is being saved, software should be OK, you can try reinstalling software and plugging the PED to a different USB port, but I don't think it will make a difference.
Test a different card to check if the card is faulty, if you do not have one, contact Brother.
Brother PED... | Answered on Oct 27, 2009
DO NOT MAKE THIS SITE WITH YOUR GARBAGE
Take your GARBAGE to another Side
Your message qualifies as SPAM
Brother... | Answered 3 days ago
dont you have anything better then be a spammer
Brother... | Answered on Sep 09, 2019
Your message does not qualify as a question or query for a problem, try somewhere else
James I am guessing you do not know which nursing home your sister is in ?
If I were you I would try the nearest nursing home to where that phone number once was attached to.
This seems to be murdoch road Wangaratta
There is an aged care facility in Murdoch road on 03 57221784
Try calling them and asking them to check if your sister's phone is operational if she is residing there and give her phone number.
Privacy laws may prevent them from conforming she lives there over a phone call.
They may ask for evidence that you have power of attorney.
Brother... | Answered on Aug 02, 2019
This is Apple's way of saying your hard ware will not be compatible to later OS updates and may fail to work with the a later OS. If it is working now, don'try about the warning. Look into updating your brother printer or downloading a more current software and drivers for the unit.
Brother... | Answered on Jun 10, 2019
Sorry but this is the wrong place to ask, we help people with technical issues ask your school counciler they can surely help you with what kind of college he should pursue
Brother... | Answered on Jan 02, 2019
I am not familiar with this specific router, but...
You can try to browse to http://192.168.0.1 or if nothing comes up, try http://192.168.1.1 - these are the most common IP addresses for routers. If you get a page showing in your browser, follow menus to Wireless and Security. You should be able to set security type and password.
Brother... | Answered on Dec 23, 2018
Denise,
I am sorry to hear of your family's loss. It would be difficult not knowing the cause, .
As my wife is a minister of religion . It can take 12 weeks if the coroner is required to investigate.
Brother... | Answered on Dec 12, 2018
Brother PED Basic Card Writer Box & Embroidery Magic II for PC  Logo
Popular Tags
53 questions posted
Top Brother Computers & Internet Experts
gary433
Are you a Brother Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Computers & Internet
Most Popular Question
windows vista downloaded
  • Computers & Internet
