20 Most Recent Kenmore Elite Hybrid Water Softener Gray More than 6 Questions & Answers
Very common with this type of unit. The switches are prone to corrosion and failure. You can buy a new timer from Sears (~$150) or off Ebay (~$100), or use a simple, no tools procedure, I use on my Sears softener.
-Unplug the softener.
-Carefully remove the top cover from the softener (usually 2 tabs in front and 2 in back).
-remove the timer panel (mine is held on by 2 tabs, one on each side).
-unplug the wiring to the timer.
-remove the timer (mine is held in place by a little plastic hook at each corner, remove one side and first and then the other.
-with the timer out, you can see the switches. while pressing on one of the switches, move your finger in a circular pattern (this rubs the contacts together on the inside of the switch, allowing the contact material to "grind" through the corrosion). Do this with all the switches.
-to reinstall, reverse the processes.
Kenmore Elite... | Answered on May 17, 2016
Steve's response is dead on. You can buy a replacement timer from Sears for $291. In addition, the lack of the unit regenerating probably caused the resin capacity to be exceeded and is permanently damaged. (Withour regeneration, the beads continue to expand and will eventually burst.)
Besides Home Depot, Sams Club, Costco, Lowe's, or Menards have low cost units and would be a better investment than putti a new timer and resin in an old unit.
Sears replacment timer: https://www.searspartsdirect.com/part-number/7288578/0042/625.html?pathTaken=partSearch&q=7288578
Kenmore Water... | Answered on Sep 13, 2019
Here are some things to look at if your ice maker is not working.
  1. water inlet valve might be defective.
  2. water filter might be clogged. Try changing the water filter.
  3. less than 20 psi inlet water pressure (low house water pressure).
  4. ro is not tubed properly (check tubing diagram attached below).
https://www.wecofilters.com/pub/media/productattach//i/c/ice_maker_kit_manual.pdf
Kenmore Water... | Answered on Mar 22, 2018
It may be time to replace the light or the Light ballast.
To reset the CHANGE FILTER indicator light, press and hold the LOCK and LIGHTkeypads until the CHANGE FILTER light blinks (approximately 3 seconds). The control for the light is now reset for another 12 months or 416 gallons of use.
Water Dispensing... | Answered on Sep 13, 2019
It screws on to the tank. Make sure to relieve water psi. Turn the water off first.
Kenmore Elite Hybrid Water Softener Gray More than 6 Logo
4 questions posted
Top Kenmore Water Dispensing & Filtration Experts
Bill Boyd
Steve Pack
Steve Pack
Dennis Webber
Are you a Kenmore Water Dispensing and Filtration Expert? Answer questions, earn points and help others
View Most Popular
  • Kenmore Water Dispensing & Filtration
Most Popular Question
pressing select button nothing want
  • Water Dispensing & Filtration
