20 Most Recent Sony Cyber-shot W290 Digital Camera Questions & Answers
the lens zoom ring is jammed, or broken , if the zoom looks broken just try to staighten it, you will hear a breaking kick noise, but it might work unless it is already broken which might require a professional service.
Sony Cyber-shot... | Answered on Dec 09, 2013
Same problem with mine.
Any solutions out there?
Sony Cyber-shot... | Answered on May 27, 2012
You can copy all the images from the Internal Memory to a Memory Stick Duo media using the COPY option in the Memory Stick Tool Menu option.
Please insert the Memory Stick Duo media with sufficient free capacity into the Camera.
Select MENU--> Settings-->Memory Stick Tool-->COPY-->OK.
The original images in the Internal memory retain after copying. You may have to delete the contents of the internal Memory. Remove the Memory Stick media after copying, then format the internal memory. FORMAT in Internal Memory Tool.
You can only copy the images to the new folder created on the Memory Stick Duo which is created automatically. You cannot copy the images to a specific folder.
Thanks for using FixYa.
Sony Cyber-shot... | Answered on May 10, 2011
according to sony support you should try first to reset your camera to the default factory settings. You can find the article here:
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C265373
and here is the manual for your camera:
http://www.docs.sony.com/reflib/docget.asp?manualid=1031952&template_id=1®ion_id=1
If you look into page 131 of the manual you can find your problem, and on page 85 is described the reset procedure: you should go to menu/settings/main settings/initialize/ then OK
Let me know if this helped you. Bye
Sony Cyber-shot... | Answered on May 06, 2011
VXDVDVSDS
Sony Cyber-shot... | Answered on Apr 20, 2011
There is a capacitor dump that you can try.
Remove the batteries, wait 5-10 minutes.
With the batteries out, press and hold the power button for 10 seconds or so.
Put the batteries back in and your camera will start over (re-boot). You will know if it worked if you have to reset the date. But if that lens is really stuck you may be out of luck. The cost to repair it will exceed the cost of a new camera.
Sony Cyber-shot... | Answered on Apr 19, 2011
I would check and confirm that you are zooming using the optical zoom. It sounds like you may be zooming using the digital zoom, which would have this effect.
Sony Cyber-shot... | Answered on Mar 03, 2011
"C:32:01 System Error" means, there's something wrong with the memory. Attach it to your computer and format the the card as 'FAT'. Formatting as 'FAT32' or 'NTFS' will produce this error.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Sony Cyber-shot... | Answered on Feb 21, 2011
That's called "cropping" and can be accomplished in photo-editing software.
Sony Cyber-shot... | Answered on Jan 18, 2011
You seem to have it set to use the smile recognition to fire the shutter. Find this feature in the menues and turn it off.
Sony Cyber-shot... | Answered on Nov 22, 2010
You can download the user manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa.
Sony Cyber-shot... | Answered on Oct 03, 2010
lens unit is bad,so take out the lens unit do service,if needs replace the deformed/damaged parts,assemble and fix that u can do taking precautions.
Sony Cyber-shot... | Answered on Jun 28, 2010
how long do you usually charged the batt? to make charge last slightly longer leave the batt inside the charger for an hour after the charger light goes off. if you have a fully charged batt you should be able to take approx. 300 pics or 2.5hrs approx.batt life. for viewing pics it should give you approx. 6800 pics and approx. 5.5 hrs. of course, number of still images and and batt life may vary depending on the camera settings.so if you're zooming in and out,using the flash,going from camera to play mode, turning cam on and off, using other settings and features of the camera, this will cause the batt to drain much faster.also ambient temperature also affects batt life.if it's very cold, the batt drains a bit faster.also, it's recommended that if you're not using the camera to remove the batt.retaining the camera settings, date & time will cause batt to drain even if your not using it. if did this and still you think it's odd that your batt drains quickly and looses charge even if it's fully charge, it might also indicate that what you might be a defective batt. one way to find out is to try using the same type of batt from a friend or a relative that has one to confirm and further isolate issue.anyway, supplied accessories has the same warranty that applies to your camera.so you may send it out and have it replaced if needed.hope this helps.thanks:)
Sony Cyber-shot... | Answered on Apr 09, 2010
Do what the pros do...use a card reader.
Sony Cyber-shot... | Answered on Feb 25, 2010
Please make sure to check if the battery is fully charged. Second, check the menu option for battery saving mode and turn it off. If the battery is getting old and not charging fully anymore the priority of the camera is the shooting mode.
Sony Cyber-shot... | Answered on Feb 19, 2010
Are you moving when you press the shutter button? Do you press the button half-way and allow the camera to lock in the focus (it will beep) before pressing the rest of the way?
Sony Cyber-shot... | Answered on Jan 07, 2010
Sony Cyber-shot W290 Digital Camera Logo
24 questions posted
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
change from internal memory external
  • Cameras
