20 Most Recent Toshiba E-studio 281c Copier Questions & Answers
Have you checked the manual under Troubleshooting?
The only thought I have is this one;
Is the equipment in the energy saving mode (Automatic energy
saving mode)?
Press the [ENERGY SAVER] or [START] button on the control
panel to clear the mode. (It takes a while for the equipment
to become ready.)
P.43 "3.Energy Saving Mode
Toshiba E-studio... | Answered on Jan 15, 2019
Your print driver is probably set to monochrome. Usually there are to drivers set up on your computer: a pcl5 for black/white, and a ps3 for color--or vice-versa. Right click your driver; you can change the setting in your preference or properties section.
Toshiba E-studio... | Answered on Feb 25, 2018
By the sounds of it the laser slit glass needs cleaned. . These machines run quite dirty so dust and toner tend to fall on the the laser unit. Either that or a dwv unit is depleted of developer material. If ur not familiar in taking the copier apart I wouldn't try it lol.
Toshiba E-studio... | Answered on Dec 17, 2017
1. Step (i) Switch the machine off
2 .Step (ii) Press and hold 0 & 8 simultaneously.
3. Step (iii) Switch on the machine
4. Step (iv) Enter the code 400
5. Step (v) Press start button
6. Step (vi) enter the value 0
7. Step (vii) Switch machine off
8. Step (viii) Switch the machine on to check for the error
Toshiba E-studio... | Answered on Mar 03, 2016
You can replace drum and blade but first you must have service manual with you.I'ts easy to change the drum and they are for 120.000 copies.So find a service manual or e-mail me to show how.
Toshiba E-studio... | Answered on Feb 16, 2016
Following this steps:
1. At first Open Front Cover and Duplex Cover..
2. Open the the fuser unit cover..
3. Then you have to take out Developer unit by Skrew driver...
4. After it, You have to take out drum unit...
U need to make sure the printer kit is installed, otherwise printing will not work. The printer kit is like a usb dongle, plugged on the usb port along with network port
Toshiba E-studio... | Answered on Dec 25, 2015
I don't think that's a valid code. Perhaps CD010? In which case there's a problem with the cleaning brushes.
Toshiba E-studio... | Answered on Apr 06, 2015
Replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Toshiba E-studio... | Answered on Apr 05, 2015
replacing the drum is usually the most effective way of regaining print quality on laser printers with no extra marks on the paper.
Go to
Toshiba Photocopiers printers and fax
and select which Windows or other Operating System you are using, and download.
Toshiba E-studio... | Answered on Apr 03, 2015
Depends what you mean by 'not clear copies'? Is this in copying or printing?
If not clear whenh copying, try cleaning the glass.
If it is not clear colour copies,because the colors are not superimposed accurately it may be you need to align the color system (see Printer Services)
If it black text, it may be the same reason, or a new cartridge or ink supply is needed. Ot it may need a good clean up on the roller or drums, or maybe just old age.
Basically u can scan to e-filing where u use file downloader software to retrieve the file.
Or scan to file(file_share) where u use smb to retrieve the file.
Toshiba E-studio... | Answered on Mar 13, 2015
If changed new toner still showing replace toner cartridge, then probably the toner not able to go inside developer or the developer material is worn out.
It can be worked with a desktop pc having windows 7 straightly configured to 281c and if the device is shared. Then u can access the desktop pc and browse 281c and send prints. Better to start with as a simple peer to peer connection use TCP/IP and observe that it can be accessed via Internet browser, If the copier utility page appear alright that means ur connected. Good Luck!!
Toshiba E-studio... | Answered on Feb 24, 2015
You will need the official software from the toshiba support site install it and it will show you toner levels
Toshiba E-studio... | Answered on Jan 24, 2015
Toshiba E-studio... | Answered on Jan 23, 2015
Toshiba E-studio 281c Copier Logo
175 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
check ink toner levels toshiba e studio
  • Office Equipment & Supplies
