20 Most Recent GE WSXH208A Front Load Washer Questions & Answers
GE WSXH208A... | Answered on Jul 23, 2019
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
GE WSXH208A... | Answered on Nov 24, 2018
It is a circuit so test the connections on the washer side.... insert a lead into one and a lead into the other... repeat until you get the correct two... right 2 will give you a reading the wrong ones nothing
GE WSXH208A... | Answered on Apr 11, 2018
please go to the website and download the user guide to give you an idea whats going wrong eric
GE WSXH208A... | Answered on Dec 27, 2017
We need the exact model number,
GE WSXH208A... | Answered on Oct 19, 2017
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
GE WSXH208A... | Answered on Oct 12, 2017
Please, check to insure that your washer is properly grounded. If you do not know what that means, call an electrician. Modern wash machines are controlled by circuit boards that operate on low voltage and are vulnerable to static electricity. Spikes or gaps in the electrical service from your power company could also be the problem. Your electrician should be able to help you with that as well.
GE WSXH208A... | Answered on Oct 05, 2017
Front loaders frequently suffer bearing failure.
GE WSXH208A... | Answered on Jul 11, 2017
Check the door gasket for any damage. A rip or a tear could be the cause of the leak.
GE WSXH208A... | Answered on Jun 08, 2016
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
GE WSXH208A... | Answered on Feb 21, 2016
GE WSXH208A Front Load Washer Logo
1,215 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
ge front load washer wont start model
  • Washing Machines
