20 Most Recent Sansui HDLCD-4212 LCD TV Questions & Answers
On the tv remote look for Mode Select, move switch to TV then "03" then press enter. Then pick up cable remote make sure the "cable button lights up ( by pressing on cable button at top) then you press guide...Voila!
Sansui... | Answered on Dec 09, 2018
0286,0288,0281,0284.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sansui... | Answered on Aug 15, 2014
You should check the cable used, disconnect and reconnect from both TV and whatever it is connected to.
Sansui... | Answered on Jan 14, 2013
The Backlights inverter, the T-CON,or the 24vdc power supply may have gone out, it will require in-depth troubleshooting. Please read below:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Sansui... | Answered on Oct 11, 2011
The USB port on HDLCD4212 is only for servicing the tv. It will not read video.
Sansui... | Answered on Jun 16, 2011
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Sansui... | Answered on May 25, 2011
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Sansui... | Answered on Feb 17, 2011
Check the power lead if it is fully plugged in, and if it still does the same thing it could be internal
problem. If the set is still under guarantee then let them to worry about it.
Sansui... | Answered on Nov 22, 2010
Less than a year old tv.Ur tv still have the manufacture warrenty.Look in ur owner manual,call the tv manufacture 1-800.... numbers on the owner manual.Talk to their customers service department,what locations or what shops they hire to call,to take care their product that still in warrenty.
Sansui... | Answered on Oct 26, 2010
Whole LCD panel needs to be replaced.
Most times is not economical.
Sansui... | Answered on May 26, 2010
www.retrevo.com/support/Sansui-HDLCD4212-TVs-manual/.../2
Sansui... | Answered on Mar 21, 2010
if you do not have the directions. first manually turn on the set. then i find the code button. it may not say the same thing but it will be similar in words. push code, then push tv, then repeatedly push power until the set goes off then find enter(or something similar). this is an automatic code find technique.
Sansui... | Answered on Nov 10, 2009
You're better off just replacing the TV because of cost. If it is still under warranty why not contact the dealer you bought it from for an authorized service center location.
Sansui... | Answered on Aug 12, 2009
Hi Matt, for what you say the internal power supply of the Combo Sansui, 110 volts a12v, is not working
Indicate model of Combo Sansui, which you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola Matt, por lo que comentas no esta funcionando la fuente de alimentacion interna del Combo Sansui, de 110 volts a12v
Indica modelo del Combo Sansui, del que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Sansui Televison... | Answered on Oct 14, 2019
go into audio settings on cable remote and change
Sansui Televison... | Answered on Oct 08, 2019
go into picture settings and change view
Sansui HDLCD-4212 LCD TV Logo
28 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
sansui tv doesnt read usb video
  • Televison & Video
