20 Most Recent ASUS P5KPL-AM SE Motherboard Questions & Answers
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
ASUS P5KPL-AM SE... | Answered on Nov 21, 2017
do you have large enough power supply? It's possible the card is bad...
ASUS P5KPL-AM SE... | Answered on Aug 02, 2017
get into the power saver setting or simply click on the sleep button in the start up area
it is in the drop down box when you select user
ASUS P5KPL-AM SE... | Answered on Jun 19, 2017
i want to sound driver for win8
asus P5KPL
ASUS P5KPL-AM SE... | Answered on May 14, 2016
Hi , your mainboard uses AMI bios , "4 LED blinks" during POST appears to be a system memory related issue, some installation or compatibility.
If the display is viewable I suggest run a self booting system memory test to test installed ram memory
ASUS P5KPL-AM SE... | Answered on Nov 02, 2015
replace ur cmos battery.
ASUS P5KPL-AM SE... | Answered on Apr 07, 2015
Hello there,
Below is an image of *********** Board with number indication and wiring explanation. From your manual page 1-6 you can see the image below and 1-7 for the connector, jumpers, slots. as indicated in your problem I will only answer problems related to the wirings.
  • For the Front Panel
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with IntelĀ® Front Panel I/O Connectivity Design Guide.
  • For the USB connectors
1. If your casing has a USB header on the front bezel you can put it on any connector. You can also purchase a USB module cable or an internal card reader and plug the headers to any of those connectors.
Note: Observe Polarity, do this Vcc, -Data, +Data, Gnd ,(NC) ground is always near to NC.
Plug it at your own risk, reference image are already shown.
  • Front Panel Audio connectors
1. Look for FP_Audio header from your casing and plug it to the connector.
*Asus recommend you connect a high definition front panel audio module to this connector to avail of the motherboard's high-definition audio capability.
Hopefully this information helps.
Thank you for using FixYa.
ASUS P5KPL-AM SE... | Answered on Oct 02, 2014
Here is the homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KPLAM/#specifications
I think the power supply maybe malfunctioning or the graphic card.
Look also for bad caps on the mainboard:
If you are useing the onboard graphic buy a graphic to add on the mainboard in the 1 x PCIe x16 slot.
Check also the screen/cable for malfunctioning.
Good luck
ASUS P5KPL-AM SE... | Answered on Jul 11, 2014
Hi, have you got this board installed in a case, with all the connections made? Usually there's a two pin connector to a microswitch that detects if the case is open. If you can identify that on the board you can short the switch, fooling the system into thinking the case is closed, to get inot the bios etc.
ASUS P5KPL-AM SE... | Answered on Jun 05, 2014
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to your desired device ,press escape then press f10 to save to cmos to restart
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
hope this helps
http://repairerrors.net/error-1313.html
ASUS P5KPL-AM SE... | Answered on May 23, 2014
http://www.cleanerrors.com/fix/error-9393/
Then hard reset the router. WARNING! You MUST have the username and password to log back onto your broadband service if you do this. Internet service provider usually sends you a welcome letter with these details. Also, take down the settings on the connection page of your router (if you dont know what this page is, you should leave this to someone that does).
Generally there is a tiny hole/button on the rear of the router that should be pressed in for 10 seconds. This may vary with router model.
ASUS P5KPL-AM SE... | Answered on Apr 27, 2014
always restart???check the button maybe brocken or malfunction...
ASUS P5KPL-AM SE... | Answered on Feb 10, 2014
1. Make sure the internal connections of your sound device are ok.
2. Make sure you have properly installed the right sound driver(s)
3. If all the above have failed to resolve your problem, then you have to check whether something on your motherboard has been burned...
ASUS P5KPL-AM SE... | Answered on Feb 09, 2014
ASUS P5KPL-AM SE Motherboard Logo
341 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
audio driver p5kpl am se windows 7
  • Computers & Internet
