20 Most Recent Kenmore Elite 45986 Front Load Washer Questions & Answers
does it drain out all the water? after it stops or is there still water sitting in the tub?
Kenmore Elite... | Answered on Sep 28, 2019
AC h1 is actually AC hi error which means input voltage is too high. Wait for sometime for voltage to stabilize Washing machine will automatically start. If not call electrician to check electrical fault for high voltage
Kenmore Elite... | Answered on Jun 09, 2019
Strangely enough, I found the problem to be in the motor. If the noise becomes pronounced during the high speed spin cycle, then that is the problem. I had a repairman out for mine and they wanted to replace the drum, however when I took off the back and removed the belt, I could turn the drum separate from the motor and could hear that the problem was in the motor bearing, not the drum. Hope this helps.
Kenmore Elite... | Answered on May 03, 2019
Take the front panel off your washer. Inside the washer attached to the side you should find a manual that will help you with the error codes.
Kenmore Elite... | Answered on Jul 09, 2018
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Kenmore Elite... | Answered on May 05, 2018
Okay the bad news is most likely the bearings in the back of the front load drum are damaged and there may even be some cracking in the back this is causing it not to spin properly it will not be able to work for much longer and if you would need a major repair to fix many cases it is not worth fixing front loader because the average repair cost is around $400 you might want to get it looked at by an appliance professional but most expensive see the links below for more information Replacing the bearings on Kenmore HE3t front load washer Part 1 By How to...
Kenmore Elite... | Answered on Mar 05, 2018
If your washing machine is still under the manufacturers warranty I don't believe Sears should be charging you anything for the call. But, if you wish to steer clear of that mess and repair the washer yourself, I can give you some advice. The problem is your door latch assembly. The "Fdl" displayed is a failed door latch error code. If it is occurring intermittently right now, you are simply going to buy some time before it eventually goes bad. When it does, the washer will not run. The part number is 1094190 and costs about $50. Just to be sure, post back with comments as to your model number (located along the door frame opening) and I will research to ensure the part number is correct. The latch assemblies have not changed over recent years and are interchangeable between model numbers. If you still wish to repair yourself, I can also give you step-by-step instructions. It is not a difficult repair, but it is a little tedious. Let me know. I hope this helps you.
Kenmore Elite... | Answered on Feb 25, 2018
what's the model number,this is a drain problem to long to drain,check the pump to see if anything is in there blocking it or you have a bad pump.
Kenmore Elite... | Answered on Feb 07, 2018
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Kenmore Elite... | Answered on Jan 26, 2018
The tub support bearing may be worn.
Kenmore Elite... | Answered on Jan 23, 2018
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Kenmore Elite... | Answered on Jan 13, 2018
Always start with the simplest thing, verify that the outlet is good before troubleshooting the machine. I cannot tell you how often the home electrical is the problem not the machine.
Kenmore Elite... | Answered on Dec 01, 2017
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Kenmore Elite... | Answered on Nov 13, 2017
Kenmore Elite 45986 Front Load Washer Logo
4,936 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
Elite Kenmore
  • Elite Kenmore
Most Popular Question
kenmore elite he3t front load gets down
  • Washing Machines
