20 Most Recent Kenmore 24032\24036 Top Load Washer Questions & Answers
Its the transmission. Try to find a used appliance store in your town. Most save used parts and you should be able to pick up a used tranny for around 100 bucks.
Kenmore... | Answered on Aug 29, 2019
Loosening top plastic nut and removed top 1/2 of agitator, then loosened nut to lift out bottom 1/2 of agitator.
Kenmore... | Answered on Jun 27, 2019
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Kenmore... | Answered on Nov 09, 2018
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Kenmore... | Answered on Sep 07, 2018
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/11066862500-Kenmore-Parts-DRYER-manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Kenmore... | Answered on Apr 27, 2018
If the lid switch is faulty, or incorrectly adjusted, the drive motor is prevented from running. You do not say whether your repair man replaced the switch or the mechanism, but draining and spinning will only happen when the lid switch is engaged.
Kenmore... | Answered on Mar 02, 2018
Under the lid there should be a small hole with a push down flap and that should be the automatic stop, which can either be a bad switch under the top of the machine or could be a broken trip/ prong on the lid that pushes this button when the lid is dropped. When the machine reaches it's spin cycle time leave it turned on and raise the lid push down on this flap with something careful to keep hands out of the washers tub and see if it works then!
Clutch needs to be replaced that is why it is not spinning out. There is a clear rubber hose that goes from the fill valve on the top left of the machine down towards the bottom of the tub on the right side under the cabinet. Check and see if that hose has a hole in it of possibly came loose on either end.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Kenmore... | Answered on Feb 13, 2018
Fixya needs a model # for us to help. Thanks
Kenmore... | Answered on Jan 31, 2018
Just clean the filters off bluffs or coins and if not check the pump.
Kenmore... | Answered on Jan 10, 2018
Turtle nob until it respnds. Sound out of time
Kenmore... | Answered on Dec 26, 2017
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Kenmore... | Answered on Dec 01, 2017
I bet your problem is in the timer control. There is a piece of cardboard that can be easily removed. You can then see metal extension rods with contacts attached. These rods can be adjusted so the contacts can make better contact. Here is a link to help you better understand. https://youtu.be/pdiDGySo3uI
Kenmore... | Answered on Nov 05, 2017
Sounds like a control board issue
Kenmore... | Answered on Nov 04, 2017
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Kenmore... | Answered on Nov 03, 2017
I expect you will need to dismantle first and examine each part as it is removed and make a list.
Your description indicates at least a main bearing problem but with what seems to be such a complete failure there is certain to be "failure-related damage" to consider.
Kenmore... | Answered on Oct 23, 2017
3,909 questions posted
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
indesit washing machine
  • Washing Machines
