20 Most Recent Motorola E1000 / E1060 / E1070 / E1120 / e398 / E6 / E680 / E680i / E770 / E815 / e816 / E895 MOBILE... Bluetooth Headset Questions & Answers
Long press P3 and check key sign will be goes OFF, now your keypad is unlock.
Motorola Radio... | Answered on Nov 03, 2019
please, try long press P2 button, to unlock your radio,
and re-try,
Thank you,
With Regards,
jack
It requires the radio programming program. You must take it to a dealer. It will cost a bit to be reprogrammed, call in advance.
Motorola Radio... | Answered on Oct 04, 2019
Entering Front Panel Feature and Button
Configuration Mode
If your radio is turned ON, turn it OFF. Press and hold the side
programmable button 1, and turn your radio ON. A tone is
heard, indicating that your radio is in Feature and Button
Configuration Mode. The indicator illuminates and the
"BCKLIGHT" is displayed on the radio LCD screen.
Whenever the radio is turn on, it initiates a self-test routine which checks the RAM, EEPROM
hardware and EEPROM checksum. If Self Test passes, the green LED flashes once and a Self-Test
Pass Tone is generated. If unsuccessful, the red LED flashes rapidly and a Self-Test Fail Tone is
heard
You may need the programing software to do the reset the manual does not give you any info on resetting the radio
Motorola Radio... | Answered on Oct 03, 2019
No. Your Talkabout radio operates on UHF and your wife's walkie talkie is a VHF radio operating on exclusive business frequencies.
Motorola Radio... | Answered on Sep 26, 2019
Hi PC Bedwell, check the battery charge, it may be needing to be replaced, likewise, control the charger
I hope you can solve the problem
Regards Franco Dosil
Hola PC Bedwell, comprueba la carga de las bater?as, puede estar necesitando ser reemplazadas, de igual manera, controla el cargador
Espero puedas resolver el problema
Saludos Franco Dosil
Motorola Radio... | Answered on Sep 20, 2019
Check your Private Line (aka interference eliminator code, tone code, PL, quiet call). It sounds like you have one radio set with a PL setting and the other one is open squelch (no private line). All settings for frequency and PL code need to be the same between the two radios.
We don't have a manual for the T3, but I am attaching one for the T5, which may be similar. http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/TLKR-T%20series/Static%20Files/T5%20Manual%20EU.pdf
Best regards.
Motorola Radio... | Answered on Aug 31, 2019
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. radiodude365@yahoo.com
Motorola Radio... | Answered on Jun 16, 2019
Turn off your CTCSS or DTS functions. You will have to go into the set up menu for this.
Motorola Radio... | Answered on Jun 04, 2019
You must have the RSS (radio service software) software and the correct cable. There is no resetting without these.
Motorola Radio... | Answered on Apr 15, 2019
Motorola E1000 / E1060 / E1070 / E1120 / e398 / E6 / E680 / E680i / E770 / E815 / e816 / E895 MOBILE... Bluetooth Headset Logo
6 questions posted
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Motorola Radio Communications
Most Popular Question
need dowmn load pc suit
  • Radio Communications
