20 Most Recent Paradigm AMS-250 Speaker Questions & Answers
Red +. Green - for the right channel. White + and Black - for the left. This is the most common color code.
Paradigm AMS-250... | Answered on Oct 07, 2010
did u get ur answer to your fuse problem
Paradigm Audio... | Answered on Jun 09, 2019
100-240v 1.6amp is what it says.
I am trying to work out if you have damaged the speakers and amp too.
Have you tried a pair of headphones on the amp? If they sound ok then your amp is fine.
Assuming it is, then speakers have what's called crossover units in side each of them. This splits the sound into three parts. Bass, midrange, treble. The bass is handled by the woofer's, the midrange by a middle sized speaker or or it's combined with a tweeter, which of course handles the treble.
Connecting a 1.5 volt battery across any of the individual speakers will cause it to pop if working. If the speaker then is not getting sound then the crossover unit is to blame.
When you look at the crossover unit, it will have coils and capacitors (non polarised) on it. The bigger ones deal with the bass and the smaller ones treble. If you find a fault say on the crossover of the speaker, for example no treble comes out of it. Then start by replacing the capacitors. Use the same value as on the capacitor and remember they fit any way round.
Paradigm Audio... | Answered on Apr 16, 2017
Here's the Owner's manual -> https://docs.google.com/viewer?url=https%3A%2F%2Fwww.paradigm.com%2Fdownloads%2FOM-100.pdf.
There are many ways to connect the system depending on your receiver's outputs and the speakers. Usually, the TV L/R output connects to one of the receiver's inputs. The receiver's preamp sub output goes to the powered subwoofer. The receiver's FL/C/FR/SL/SR/RL/RR speaker outputs go to the respective speakers.
Paradigm Audio... | Answered on Mar 03, 2017
Look for any screws that are holding it together and remove them.
Paradigm Audio... | Answered on Jan 13, 2017
Try using a "cheater" plug at the electrical outlet to the wall for your front end equipment. It does a "ground lift". If your equipment plug is 3-prong, a cheater plug will make it a 2-prong.
Paradigm Audio... | Answered on Nov 08, 2016
The inside of a subwoofer isn't really a great place to put an amplifier, that that is what you have. These things do go bad from time to time.
You may be able to get it repaired, or you could replace the amp. You're looking for a "plate amp". Parts Express has a good selection:
Subwoofer Plate Amplifiers
Paradigm Audio... | Answered on Oct 14, 2015
The amplifier that powers the sub is the source of your problems. Sounds like some power supply filter capacitors are failing.
Paradigm Audio... | Answered on Dec 31, 2014
Paradigm AMS-250 Speaker Logo
Popular Tags
1 questions posted
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Marvin
Marvin
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Paradigm Audio Players & Recorders
Most Popular Question
pa radigm ams 250
  • Audio Players & Recorders
