20 Most Recent Triumph 400T Treadmill Questions & Answers
Try to buy a new key. may the old once magnetic property may degraded.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Triumph 400T... | Answered on May 13, 2016
Lube the treadmill belt with treadmill lube
Triumph 400T... | Answered on Dec 27, 2014
Ok. So the first thing to try is to calibrate the speed.
You do this by doing the following:
  • With the SAFETY KEY in place, hold the ELEVATION UP and SPEED DOWN buttons for five seconds. The console will beep twice, "ENG0" will appear in the Distance window, and a number will appear in the Elevation window.
  • Press SELECT until "ENG3" appears; this is for Auto-Calibration.
  • Press START to Auto-Calibrate.
  • The treadmill will calibrate minimum and maximum speed, and minimum and maximum elevation. When Auto-Calibration is complete, the treadmill will reset to User's start screen. This process takes three to five minutes.
Make sure there are no errors. . .and that the speed goes from super slow to super fast and then stops. . .. if it stays slow. . or stays fast. .or error code appears during calibration, there is a problem.
If after a good calibration sequence, if it still does the stopping and E-1 after 10 seconds. ., then you need to (Power off and disconnect treadmill). . .then unplug the speed sensor from the lower power board, blow into the connector on the wire, and add a little contact cleaner spray to the connector on the board.
Recap: If it actually runs. . .but stops after a few seconds. . but the calibration runs and passes fine. .. .more than likely it is a speed sensor misread or a faulty speed sensor.
Triumph 400T... | Answered on Oct 19, 2014
Triumph 400T... | Answered on Jul 18, 2013
Triumph 400T Treadmill Logo
12 questions posted
Top Triumph Exercise & Fitness Experts
Don Eagan
Tom Chichester
Treadmill Repairs...
Are you a Triumph Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Triumph Exercise & Fitness
Most Popular Question
key not stay connected when in use
  • Exercise & Fitness
