20 Most Recent Apple iPad 16 GB 3G Tablet PC Questions & Answers
As for unlocking iPad, there are several ways you can resort to. Just follow one of them as below shows.
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
2. Wait for the process to finish. Then you can set up and use your device.
For more methods, check: How to Unlock iPad?
Apple iPad 16 GB... | Answered on Jul 18, 2019
This is a job for an Apple Genius. You will have to make an appointment online with a local Apple store.
Apple iPad 16 GB... | Answered on Sep 07, 2018
install the kindle app, and when you log in with your amazon credentials, they will be synched
Apple iPad 16 GB... | Answered on Aug 23, 2018
That behaviour is strange. I've never seen anything like that happen and i've owned iPads from the first version on.
I strongly suggest you make a last backup and then use iTunes to reinstall the iPad.
It might be a good idea to start without using the backup and test if turning off is working as expected then. After that reinstall the iPad again and use the Backup you made first to have all your settings, apps and such back. If the problem returns it's in the backup ....
Apple iPad 16 GB... | Answered on Apr 17, 2018
Open Safari & go to URL
https://itunes.apple.com/sg/app/showbox/id793056594?mt=8
bobwin
Apple iPad 16 GB... | Answered on Mar 16, 2018
You will need Apple Composite AV Cables to connect the iPad to your television. The cables can be purchased online or at your local Apple store.
You can also stream your iPad to your television if you have an Apple TV by using Apple's Airplay.
Hope that helps!
Apple iPad 16 GB... | Answered on Feb 03, 2018
check with your service provider ans see what they can do ..
Apple iPad 16 GB... | Answered on Mar 10, 2015
Push and hold the app icon until it starts to wiggle. You will see an X appear click the X to remove the app.
For the iPad first generation (A1219) to update is only possible with connecting the device to iTunes on a computer.
- this model supports only iOS 5
- no iOS 6/7/8 possible !
ipad-1-update-qrl052hdp2kg0kvuqxssgusw-4-0.jpg ipad-1-update-qrl052hdp2kg0kvuqxssgusw-4-2.jpg ipad-1-update-qrl052hdp2kg0kvuqxssgusw-4-5.jpg
Apple iPad 16 GB... | Answered on Dec 28, 2014
The Apple ID is different from the iPad password, and is handled through iCloud. You may want to pursue this in Apple's help web site:
http://help.apple.com/icloud/#/mmfc0f1a3b
Apple iPad 16 GB... | Answered on Aug 18, 2014
you can reset your iTunes password from the iTunes web site, and the associated em address. and restore the iOS device on your computer with the iTunes app
Apple iPad 16 GB... | Answered on Jul 22, 2014
Simply access the Kindle library on your iPad (last screenshot here: http://iphoneappbackup.wordpress.com/2014/06/23/how-to-read-kindle-books-on-ipad/) and delete the books of your choice from there.
Apple iPad 16 GB... | Answered on Jun 25, 2014
Do you have a case on the iPad? Sometimes an ill-fitting case can trigger the buttons by itself. If there is any lint or dirt between the case and the iPad, it can cause the same issue. If you have headphones with a volume controller on the cable - check that that is not being pressed by accident. You can also check to see if there is any lint caught inside the headphone hole. Sometimes that can cause a little electrical short and trigger funny behavior on the iPad. If none of those solve your problem, take it to the apple store, it could just be a faulty switch.
Apple iPad 16 GB... | Answered on Jun 19, 2014
GOTO SETTING/APPLICATION/AND UNINSTALL.
Apple iPad 16 GB... | Answered on Jun 05, 2014
You need to contact the wireless carrier and they will give you a PUK unlock code.
Apple iPad 16 GB... | Answered on Apr 09, 2014
download from the ibooks app in spanish
Apple iPad 16 GB... | Answered on Jan 20, 2014
hard reset, press and hold both home and power button until it shuts off, your data is safe!
Apple iPad 16 GB 3G Tablet PC Logo
Popular Tags
112 questions posted
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
delete farm heros from apple ipad
  • Tablets & eReaders
