20 Most Recent Kyocera Mita KM-3035 All-In-One Laser Printer Questions & Answers
Check to make sure that their is no paper that is jammed in the paper draw. Also open the main panel where you would change the toner and pull out the little draw underneath the toner, I believe it is marked A2. Make sure that there is no paper there as well. Another place that paper will sometimes hide is in the left panel by the duplex system. Sometimes a little piece of paper gets left behind and this can cause the system to think there is still paper jammed in the machine. If all else fails try restarting the system. If you are still experiencing a problem than I would recommend you call your servicing dealer.
Hopes this helps.
Henry
Kyocera Mita... | Answered on May 28, 2019
1087*2 then 251 and press start it will bring some digits then you clear
Kyocera Mita... | Answered on Mar 07, 2019
check main charger assy.
Kyocera Mita... | Answered on Oct 18, 2018
Try Googling (Kyocera)(KM-3035)(manual) without parens for instructions.
Kyocera Mita... | Answered on May 21, 2018
scanner card has to be installed in device. scanner file utility has to be use. Or card will have to configured to your network, scan to pc, scan to email, etc
Kyocera Mita... | Answered on May 17, 2018
Print/Scan System (U) 083H9503 Network Print Controller and Network Scanner
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Are the TWAIN drivers installed on the computer?
Kyocera Mita... | Answered on Apr 27, 2018
Make sure the connector cable from the finisher is plugged into the copier. Unplug the copier power cord first if you have to reconnect it.
Kyocera Mita... | Answered on Apr 27, 2016
clean the LASER glass for that color, if you dont know what that is get a tech out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Kyocera Mita... | Answered on Jan 30, 2016
Press the STATUS KEY
With the numeric key pad key in 10871087 (if done correctly the display will change and say ENTER MAINTENANCE ITEM)
Enter 201 with the numeric key pad (follow the steps below):
1. Press the start key. 2. Select the [INITIALIZE].
3. Press the start key.
4. Press the center of the + keys. Be sure to press three + keys displayed in order. The touch panel is adjusted automatically.
5. Press the indicated three + keys, and then check the display.
6. Press the stop key. The screen for selecting a maintenance item No. is displayed.
Completion Press the stop key. The screen for selecting a maintenance item No. is displayed.
Now to exit maintenance mode key in 001 with the numeric key pad
Press the Start Key ( you should be back to the status screen, press copy key to go back to the copy mode)
Remember do not go to any other maintenance mode or make any other changes.
Kyocera Mita... | Answered on Jun 26, 2015
http://usa.kyoceradocumentsolutions.com/americas/jsp/upload/resource/11858/0/3035-4035-5035ENOGR6.pdf
Kyocera Mita... | Answered on Jun 05, 2015
What is the question??
Kyocera Mita... | Answered on May 25, 2015
that because that local auctio take the fax card
go to him and ask for it
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
236 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
system error
  • Office Equipment & Supplies
