20 Most Recent Datamax I-4208 Thermal Label Printer Questions & Answers
im not sure about datamax but on a zebra theres settings for media types like continuous or tear off. maybe thats it?? does it calibrate correctly?
Datamax I-4208... | Answered on Oct 08, 2017
Itello: This happened in this cases:
label sensor is dirty or uncalibrated
label or tag is out of position
Execute a label quick calibration pressing and hold FEED button by 5 - 7 seconds and release. Also clean the label sensor.
Roberto Martinez
padrino99@prodigy.net.mx
Datamax I-4208... | Answered on Feb 01, 2017
menu - media settings - print mode - DIRECT THERMAL
Datamax I-4208... | Answered on Feb 10, 2016
go to menu - media settings - sensor calibration
follow the steps
Thermal can mean "Direct Thermal" (no ribbon) or "Thermal Transfer" (with ribbon). If you want to print using Direct Thermal labels you need to select Direct Thermal from Media Settings in the Menu accessed from the Control Panel on the front of the printer. Otherwise, the printer sensors will look for a ribbon that is not there, and you will see an error message.
Datamax I-4208... | Answered on Feb 17, 2015
To view or set the IP Address on a Datamax I-4208, use the Front Control Panel on the printer and follow these steps:
Press Menu, go to Communications, then NIC Adapter, then IP Address.
Datamax I-4208... | Answered on Aug 28, 2014
Just print out the configuration through test button
Datamax I-4208... | Answered on May 26, 2014
When printing on less than full width media, the printer has a printhead-leveling cam to adjust the right side of the printhead
for even pressure distribution. To adjust the leveling cam:
1. With media loaded in the printer, print a label (press the
FEED + CANCEL buttons simultaneously) and
examine it..
2. While observing the printed labels, loosen the
Thumbscrew and move it to the left most position. (see
Example 1, below).
3. Next, move the Thumbscrew to the right until the
printed labels contain a complete, even image (see
Example 2). Tighten the Thumbscrew.
Datamax I-4208... | Answered on Apr 30, 2014
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Datamax I-4208... | Answered on Apr 29, 2014
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
If the word "VOID" prints, turn the printer off, reboot your computer, turn the printer back on, and try printing again.
Datamax I-4208 Thermal Label Printer Logo
147 questions posted
Top Datamax Office Equipment & Supplies Experts
Joseph Mueller
Joseph Mueller
Pierre Legault
Jeremy Hoyle
Jeremy Hoyle
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
I Datamax
  • I Datamax
Most Popular Question
39 m having problems digital display
  • Office Equipment & Supplies
