20 Most Recent Datamax DMX E4203 Printer Questions & Answers
Dear
Pl. check your printer setting for no. of labels. in the pc.
thanks.
Datamax DMX... | Answered on Mar 17, 2015
The Media Sensor is not seeing the labels or is not configured for these labels. Check Media Sensor position and settings. The Fixed Sensor models have a small window for the sensor at the bottom of the printer, about 3/8" to the right of the left side. If the printer has a movable sensor, the typical position is either 1" to the right of the left edge of the labels, or in the center of the labels. Typical media sensor setting is "Gap Mode". Another common issue is that the sensor might have a piece of label or something stuck to it, covering the lens. Finally, there is a possibility that the reflectivity threshold may need to be recalibrated (see below). This can be difficult, although there are instructions in the Operator's Manual. If physical position/clear view of labels by sensor doesn't seem to be the issue, an easier way to deal with settings issues might be to Restore to Factory Defaults (see below).
Datamax E-Class Auto Media Calibration Procedure:
The 'Auto Media Calibration Procedure' allows the operator to
automatically obtain the optimum (TOF Low and TOF Delta) values for
a particular media. These values are useful for media that continues to
have troubles after Media Sensor has been manually calibrated (usually
preprinted media). This operation feeds 10 inches of media using the
current Media Sensor Calibration setting and calculates the TOF Delta
and TOF Low values to be used. Upon completion the printer will exit
back to 'Calibration Mode' flashing the PAUSED light if successful or
the FAULT light if not successful.
Note: Before calibrating, be sure the media sensor is set for the
appropriate media type, see section 4.4.2, also be sure the
printhead is latched down and the cover is closed.
To perform the Auto Media Calibration complete the following steps:
1. Load the desired media.
2. Hold the button while powering up the printer. Continue to hold
the button until the PAUSED light turns off then release.
3. Next press the button, (the printer will now calibrate to the
media)
4. The PAUSED light will flash 5 times to indicate a successful
calibration. The FAULT light will flash 3 times to indicate an
unsuccessful calibration.
Note: If you wish to discard your changes and revert back to the
previous calibration simply turn off the printer before Step 5.
5. Now you can save your changes and resume by again
pressing the + buttons simultaneously.
Datamax E-Class Reset to Factory Defaults Procedure:
With the printer off, press and hold the F1, F2, and F3 buttons while
turning the printer on. Continue to hold the buttons down until the
PAUSED light turns off. The printer will now be set to the 'Factory
Defaults'.
Datamax DMX... | Answered on Jul 22, 2014
Free Windows Printer drivers for Datamax can be downloaded here: Custom Design Label Systems from Able Label Systems
Look for the link toward the bottom labeled "Free Thermal Printer Drivers."
Datamax DMX... | Answered on Apr 29, 2014
No, you do not need a proprietary Windows program for Datamax E4203. But you do need the correct driver. You can download them for free - see the link on the Able Label Systems Thermal Printers page. Follow the links and look for the Datamax download. This may or may not solve your Checkpoint error message, but it is all that is normally required in order to enable standard Windows-based programs to access your E4203.
Datamax DMX... | Answered on Apr 16, 2014
I doubt the sensors would have anything to do with only printing half a label. I'm not familiar with the E-class series of printers, but the common causes of that problem that I've seen before with the larger M & I class printers can be:
1) A piece of label or ribbon is stuck on the printhead.
2) The printhead is not seating properly on one side, causing the printhead to be too far away from the label & platen roller to apply enough pressure in order to print.
3) A printhead cable is not seated fully somewhere and not supplying the signals properly to that half.
4) The main logic board is bad.
5) The printhead is bad.
6) There is a software problem or label configuration setting that needs to be corrected that controls the print width.
Datamax DMX... | Answered on Feb 26, 2014
We have the same problem and Datamax had us clean the roller and the head. it worked for awhile and then the line came back. You could try it, maybe it will work better for you.
Datamax DMX... | Answered on Feb 11, 2014
http://www.datamaxcorp.com/software/e-class/
There u go!
Manuals, drivers, firmware and utility for the E-class,E-4303,E-4204 and E4304
Good luck
Nic
Datamax DMX... | Answered on Jan 23, 2014
Datamax DMX E4203 Printer Logo
Popular Tags
43 questions posted
Top Datamax Office Equipment & Supplies Experts
Joseph Mueller
Joseph Mueller
Pierre Legault
Jeremy Hoyle
Jeremy Hoyle
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
DMX Datamax
  • DMX Datamax
Most Popular Question
datamax printer
  • Office Equipment & Supplies
