20 Most Recent Toshiba E-STUDIO 450 Copier Questions & Answers
Hello
F120 error is Database Abnormality
Please switch off the machine
While holding down 0+8 buttons, switch the machine, when in test mode please input 684 and press the start button. that will rebuild the databases. Then input 690 and intialize the hard drive.
Good luck
Toshiba E-STUDIO... | Answered on Apr 29, 2019
what your problem i cant understand is c470 OR e030
Toshiba E-STUDIO... | Answered on Feb 16, 2019
Hello
I encountered the same problem a few years back, I found the power supply to be faulty.
You can try checking all the fuses on the power supply.
Sorry that is all i have at the moment.
I will see if i can download the pcboard repair manual.
Please let me know where i can email it to.
Regards
Toshiba E-STUDIO... | Answered on Sep 17, 2018
The problem is this :
Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON.
the solution is to change thermistors
Toshiba E-STUDIO... | Answered on Oct 10, 2017
C410 is fuser temp related erro. Could be bad thermistor, worn roller or open thermostat. If you can't reset in 08-400 to 0, parts are needed.
Toshiba E-STUDIO... | Answered on Nov 27, 2014
see if the DHPC is enabled if so disable and give the IP address in copier. and ping in run command type: ping ip address space and -t to be entered to get reply.
Toshiba E-STUDIO... | Answered on Sep 22, 2014
Hello
You will have to remove the waste toner bottle, put some cleaning solvent in the bottle and wash the toner out of the bottle.
Please the bottle out to dry before you replace it in the machine.
Regards
Toshiba E-STUDIO... | Answered on Jun 26, 2014
Make sure your connecting wires are still connected and not loose. If you have a new network you will need to update it in the memory.
Toshiba E-STUDIO... | Answered on May 25, 2014
You will probably have to delete the faxes pending on your computer.
go setting menu and change paper size
Toshiba E-STUDIO... | Answered on Jan 27, 2014
124 questions posted
Top Toshiba Office Equipment & Supplies Experts
didi2005
digivisionm
Level 1 Expert
amir hamza
amir hamza
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
please help me e studio 211
  • Office Equipment & Supplies
