20 Most Recent Tellermate T-ix R3500 Money Counter Questions & Answers
USE ANY NUMBER HERE. CALL A SPAMMER AND HAVE SOME FUN TODAY!!
1-85O-8I2-4OO9.{+1-8OO-8O3-1O69 {1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 7
Retail Supplies | Answered 3 days ago
1-85O-8I2-4OO9.{+1-8OO-8O3-1O69 {1-888-499-5520 1-877-769-0969 1-888-499-5520 1-8OO-828-O294 888-348-1833 1-888-444-6538 1-855-616-7697 88
ALL FREE CALL TODAY FOR FREE INDIAN CURRY RECIPES, TRAVEL AND WEATHER INFORMATION AND TIPS...ALL FREE NEVER ANY CHARGES +1-85O-8I2-4OO9.{+1-8OO-8O3-1O69 {1-888-499-5520 1-877-769-0969 1-888-499-5520 5
ALL FREE CALL TODAY FOR FREE INDIAN CURRY RECIPES, TRAVEL AND WEATHER INFORMATION AND TIPS...ALL FREE NEVER ANY CHARGES +1-85O-8I2-4OO9.{+1-8OO-8O3-1O69 {1-888-499-5520 1-877-769-0969 1-888-499-5520 4
Hi. It has a printer error. Make sure the paper isn't jammed. If it looks ok, take it to a dealer to be checked.
Usually it's a programming error when someone changed prices.
Try this in program mode -
0 CASH SUBTOTAL
You might have to do a Z report after to clear the report before the problem goes away
Retail Supplies | Answered on Oct 12, 2019
You have a printer fault. Make sure the printer is clear of paper. Try removing the ink roller. Turn off and on. If it doesn't run, have it checked by a dealer
Unplug the scanner, then power it on again. If it reads once and then stops, it is a configuration error such as bad cable or wrong settings in register. If it doesn't read straight after power up, try scanning the 'start' barcode in the scanner's programming manual. It should always be able to read this code. If it reads it, you have a setting fault in the scanner and you need to re-program it to read UPC and EAN codes again. If it reads none of the above codes after power up, have it checked by a dealer
If it only happens in Reg mode, it normally points to corrupted memory. Usually caused by a bad battery. The only other cause I've seen is a faulty keyboard but you would normally see feeding in all modes. I'd have a dealer check the machine
You must think out of the box. The key must simply be disabled since you only want the drawer to open, presumably with access to cash/contents, etc., when authorized to do so. Superglue the key so that it will not move/function.
Retail Supplies | Answered on Oct 09, 2019
Tellermate T-ix R3500 Money Counter Logo
0 questions posted
Top Tellermate Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Tellermate Retail Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Tellermate Retail Supplies
Most Popular Question
any new software download machines
  • Retail Supplies
