20 Most Recent Hoover WindTunnel TSeries Bagless Upright Vacuum Cleaner UH70107 Questions & Answers
I had the same problem and used a tool to clean out the suction tube on my Windtunnel Series T. It was full of junk packed in tight. After cleaning it out there's no more turning off or overheating. It actually works better than when I first got it (used from a friend).
Hoover... | Answered on Jul 11, 2015
Go to your owner's manual, page 12. Remove the belt cover pieces and inspect the function of the belts and brushes, turning them by hand to confirm mechanical connection to the motor. Find the inoperative part and replace it, then simply reassemble the unit and start cleaning your carpet. ;)
Hoover Vacuums | Answered on Oct 26, 2019
There are different models of Hoover Legacy Upright vacuum, but in general, you unlatch the front cover, and pull the old bag off. The cardboard flange of the new bag goes over the tube near the top of the bag compartment
https://www.manualslib.com/manual/70085/Hoover-Legacy-Supreme-S2200.html?page=9#manual
Hoover Vacuums | Answered on Oct 21, 2019
https://www.google.com/url?q=https://www.ereplacementparts.com/hoover-fh50039-max-extract-dual-steam-vacuum-parts-c-37315_139681_139686.html&sa=U&ved=2ahUKEwiqqaHD26DlAhVRTxUIHSjDAVsQFjAAegQIAhAB&usg=AOvVaw1zwb6KrsOjvxYbzlJjXM2E
Hoover Vacuums | Answered on Oct 16, 2019
It's an issue that the front roller isn't engaged. there's usually a belt connected to the roller on one side of it. That belt is connected to the same motor that develops the suction. You have to find that area and either pull the belt over the motor and/or the brush. Close it back up and turn it on again.
Hoover Vacuums | Answered on Oct 05, 2019
Obviously some foreign matter has gotten into the moving parts. Usually this is a coin. Since it can jamb and burn-up suggest have "junk" removed before trying to use it again.
Hoover Vacuums | Answered on Oct 01, 2019
Possibly wrong hose was shipped with your unit. Suggest contact place of purchase.
See if its belt driven. If so then the roller is stuck causing the belt to heat up and smoke
Hoover Vacuums | Answered on Sep 30, 2019
that is purely normal to have cleaning material in the fresh water tank as the vac picks up the dirt from the floor it should really go into the dirty pickup tank purely normal nothing to worry about
Hoover Vacuums | Answered on Sep 26, 2019
Hoover WindTunnel TSeries Bagless Upright Vacuum Cleaner UH70107 Logo
Popular Tags
8 questions posted
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Hoover Vacuums
  • Hoover Vacuums
Most Popular Question
brush hoover windtunnel t series
  • Vacuums
