20 Most Recent Ricoh Aficio 450 Copier Questions & Answers
The best way is to update the firmware in the copier. You have to download the current firmware and put it on a flash card and and plug it in to port 2 after powering down the copier. Power it back on and the firmware will set itself up to your copier.
Ricoh Aficio 450... | Answered on Jul 12, 2019
  1. Go to this code with "Clear Mode"+107+"Clear/Stop" hold for 5s.
  2. Go to System Settings
  3. Go to 5875
  4. Check the setting of SP5875-001. If the setting is set to "1 (OFF)",change it to "0 (OFF)".
Try checking or changing the thermistors!
The metal contact spring on the thermistor broken causing all sorts of 'unrelated errors including 'Please Wait' sc 670 and sc 402...
Ricoh Aficio 450... | Answered on Jun 16, 2019
Try to reset : enter in SP mode ,open the front door and turn OFF the copier.Unplugged and Wait 2 minutes ,plugged and close the front door and turn ON the copier.If is do not work your problem is in the BICU board.
Ricoh Aficio 450... | Answered on Mar 07, 2019
RICOH ERROR CODES
Error Code Description
SC184 CIS Transmission Error
SC191 Bar Code Scanning Error SC192 Automated SBU Adjustment Error/Bar
Code Number is Different SC193 Image Transfer Error/IDU Error
SC194 SBU White Level Detection Error SC195 DF Gate Assert Error/Serial Number Error
Error SC196 DF Gate Negate Error
Code Description
SC197 DF Gate Error SC101 Exposure Lamp Error
SC198 Memory Address Error SC107 Scanner Lamp Regulator Malfunction
SC199 DF Scanning Finish Error SC120 Scanner Home Position Error 1
SC201: Polygon Motor Error HP Sensor Abnormal-Stays Off
SC220 Laser Synchronization Detection Error SC121 Scanner Home Position Error 2
SC221 Scan Length Detection Error HP Sensor Abnormal-Stays On
SC230 BCU Received no Feedback from LD SC122 Scanner Home Position Error 3
F- Gate Error SC123 Scanner Home position Error 4
SC231 Laser Beam Feedback Signal Error SC124 Scanner Motor Encoder Signal Error
F- Gate Timeout SC125 Scanner Motor Speed Error 1
SC240 LD Power Supply Excessive SC126 Scanner Motor Speed Error 2
SC260 HP Sensor Error SC127 Scanner Motor Encoder Rotating Direction
SC261 HP Sensor Not Turning Off Error
SC285 Line Position Error SC128 Scanner Motor Start Error
SC300 Charge Corona Output Error 1 SC129 Scanner Motor Speed Control Error
SC301 Charge Corona Output Error 2 SC130 SBU defective Error/Scanner Start
Charge Current Leak Abnormal
SC302 Charge Corona Output Error 3 SC131 F-Gate Asserted During Shading
Grid Voltage Error Charge Roller Current Leak
SC142: White level detection error. SC303 Charge Corona Output Error 4
SC143 SBU Auto Adjust Error Grid Leak
SC144 SBU Connection Error Charge Cleaner Motor Error SC150 Scanner ROM Mismatch SC304 Charge Roller Current Correction Error SC170 Scanner DA1 Abnormal/Video Processing SC305 Charge Corona Wire Cleaner Error 1
Error 1 SC306 Charge Corona Wire Cleaner Error 2
SC171 Scanner DA2 Abnormal/Video Processing Charge Roller Home Position Error Error 2
SC310 Potential Sensor Calibration Error 1 SC172 Scanner DA3 Abnormal/Video Processing
SC311 Potential Sensor Calibration Error 2 Error 3
SC312 Potential Sensor Calibration Error 3 SC173 Scanner Lamp Regulator Adjustment Error
SC314 Potential Sensor Calibration Error 4 SC174 Scanner DA2 Abnormal
SC315 Potential Sensor Calibration Error 5 SC181 CIS Lamp Abnormal
SC316 Potential Sensor Calibration Error 6 SC183 CIS Auto Adjust Error
SC317 Potential Sensor Calibration Error 7
www.smilecopy.com
Ricoh Aficio 450... | Answered on Feb 10, 2019
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Ricoh Aficio 450... | Answered on Jan 10, 2019
No such code for that model. But the 500 range you mention is fuser related. Replace the fuser....but parts are no longer made for that model...it was made in 1999.
Ricoh Aficio 450... | Answered on Jun 15, 2018
check the fusing unit thermistor,thermoswitch &heaterlamp
Ricoh Aficio 450... | Answered on May 22, 2018
Sorry, but I think your laser is dead ... :(
Ricoh Aficio 450... | Answered on Mar 29, 2018
It can be dirty ID sensor it retires the image unit and it cleans it… This happens when mylar of the cleaning unit is damaged…
Ricoh Aficio 450... | Answered on Jul 18, 2017
Hi.
Dear i advise you to-replace only Drum unit.
cuz i facing this problem so many time if isn't possible for you to change complete drum unit then change only drum. but if you want to check this problem just once time replace complete drum unit with drum don't fix previous drum.
and please don't wast ur time on heating unit :)
Best Regard's
Syed Babar Ali
Copier International Trading
Cell: +971556272142
Ricoh Aficio 450... | Answered on Jul 07, 2017
I post a solution for this problem see: www.fixya.com/support/t2748127-false_door_open_reading_aficio_350
Ricoh Aficio 450... | Answered on Jun 16, 2017
Most of the time is trash on the network.
Also SC990 sometimes occurs if the signal timing during scanning and printing causes a delay in the process.
There is a firmware that fix this error. You need to download it (if you know how to do it of course).
Ricoh Aficio 450... | Answered on Jun 14, 2017
Format HDD IN MACHINE.
IT WILL START FUNCTIONING
Ricoh Aficio 450... | Answered on Apr 21, 2017
Is absent Block of the Manifestation or is drived activator of the sensor, sensor burns out seldom and can be unplugged (on the right at the top on block)
Ricoh Aficio 450... | Answered on Jan 11, 2017
sc 322 is a laser unit problem. find a ricoh technician and clean the laser unit or replace it. this laser problem is hard to solve usually.
Ricoh Aficio 450... | Answered on Dec 25, 2016
Paper goes on the bottom first. original goes in top next
Ricoh Aficio 450... | Answered on Oct 01, 2016
753 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Ricoh Office Equipment & Supplies
Most Popular Question
remove user name password richo mp 4500
  • Office Equipment & Supplies
