20 Most Recent Apple iPhone 4 Black Smartphone Questions & Answers
Well, iPhone Data Recovery may help you solve your problem. You know, it is good at recovering iPhone data such as sms, contacts and more. You can follow the steps here in the following:
Step 1: Launch the program and scan to recoverStep 2: recover deleted SMS from iTunes backup files
Step 3: Start to recover iPhone text messages
For more details, read this guide:
Retrieve Deleted Text Messages on iPhone
Apple iPhone 4... | Answered on Aug 25, 2019
As for unlocking an iPhone, there are a few ways to reach this aim. Follow one of them shown below.
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more methods, check: How to Unlock iPad?
Apple iPhone 4... | Answered on Jul 26, 2019
Do you mean you have forgotten the iPhone password? If so, refer to the below steps to unlock your iPhone 4.
To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
For more methods, check: How to Unlock iPhone
Apple iPhone 4... | Answered on Jul 04, 2019
If you forgot the passcode for your iPhone, iPad, or iPod ...
https://support.apple.com/en-us/HT204306
Apple Inc.Nov 2, 2015 - If you enter the wrong passcode in to an iOS device six times in a row, you'll be locked out and a message will say that your device is disabled. ... If you're signed in to iCloud and Find My iPhone is enabled, use iCloud. If you don't use iCloud and you can't ... If it doesn't, learn what to do. Once the sync and ...
How to remove/reset any disabled or Password locked ...
? 5:31
https://www.youtube.com/watch?v=csLUmaDTHl4
Oct 30, 2014 - Uploaded by Karlos Corner
iTunes will alert you that it has detected a device in recovery mode. 6. .... easy and fast to activate/unlock/jailbreak/bypass every iphone from 5s to 6s without having any problems. use "newunlockiphone,net". .... +Clair Glen My iPhone is disabledfor 23,760,796 minutes. ... Do you need an ITUNES account?.
Top Ways To Unlock iPhone Disabled - YouTube
? 2:35
https://www.youtube.com/watch?v=KiWp28QTToQ
Jan 1, 2014 - Uploaded by CocTubes
How to Unlock Your iPhone When Its Disabled .... me use myfingerprints like it normally does. of anyone has anyway of helping.... What to do?
Apple iPhone 4... | Answered on Jun 19, 2019
connect your iPhone to computer via the iPhone charger. in iTunes you can sync your phone to your computer.
Apple iPhone 4... | Answered on Jun 06, 2019
iCloud password should be the same passwords as your apple id
Apple iPhone 4... | Answered on Mar 09, 2019
You might try holding down the power and home buttons at the same time. Wait until you see the silver apple. Thats what I did when mine wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut down your iphone...and leave it there for how ever long it takes to charge...(to be able to use it again is about 30 minutes)depends on your energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do not plug it into your iPhone. Then press and hold the home button on your phone while conecting the iPhone cord into your iPhone continue to hold down the home button. Then click restore in iTunes
Apple iPhone 4... | Answered on Oct 27, 2018
Very simple.
When you sync. your phone first see whet is on the phone. See ibooks here you unselect the ibooks then click on apply.
Apple iPhone 4... | Answered on Sep 05, 2018
To recover deleted sms from iPhone, the easy way is using pro iPhone data recovery software. No matter there is a backup or not, we can easily recover deleted or lost sms from iTunes backup files or iPhone directly. Recover Deleted Text Messages on iPhone 8 Recover Deleted Text Messages on iPhone 8
Apple iPhone 4... | Answered on May 15, 2018
You can't block incoming unknown calls, but if you don't accept the call, you will not pay for it.
Apple iPhone 4... | Answered on Mar 26, 2018
It actually depends on the firmware from your provider but...
bring up the call log. Tap on the Info icon on the right hand side of the number you want to block. That should bring up the menu of options of what to do with the number; one of the options will be to "block this number"
Unblock by going to:
  1. Settings
  2. Phone
  3. Blocked
  4. Edit
  5. Delete number you no longer want to block.
Look this up on youtube. It is a complicated answer but it can be done by following the proper instructions.
Apple iPhone 4... | Answered on Mar 20, 2018
Put the device in DFU mode and restore
You may have the wrong iTunes for that update (you need the newest iTunes in order to restore iPhone's). You might also be installed a outdated iOS, or a higher version than the device you are running can handle.
Does you new blue tooth device appear on other device or not. Reset you iphone setting and then again try to detect your new bluetooth device. Also check your bluetooth setting on your iphone to. Here is how to fix computer does not detect iphone or ipod
http://ipodtips-tricks.blogspot.in/2016/04/ipod-touch-does-not-detected-by-computer.html
Apple iPhone 4... | Answered on Dec 27, 2017
How old is the phone?
It maybe out of warranty, but it may still be covered by consumer warranty???
Water damaged hmmmmmmm
Contact apple
Good luck
Apple iPhone 4... | Answered on Nov 18, 2017
The china iphone clones are not actually iPhones - they are usually android phones with a skin that makes them look like apple products. The clue is the fact you have Java installed, which is used my Android and not iOS (Apple's iPhone OS). Your phone will never work as a real iPhone.
Apple iPhone 4... | Answered on Nov 16, 2017
Apple iPhone 4 Black Smartphone Logo
821 questions posted
Popular Products
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
want open new apple account but iphone
  • Cell Phones
