20 Most Recent Amazon Kindle 3G Questions & Answers
You need to contact Amazon Customer Service - 888-280-4331
Amazon Kindle 3G | Answered on Jul 31, 2019
Download the manual by clicking on the link below.
kindle.s3.amazonaws.com/Kindle_User's_Guide_English.pdf
Hope this helps.Thankyou!
Amazon Kindle 3G | Answered on Jul 12, 2019
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Amazon Kindle 3G | Answered on Jun 06, 2018
See the Kindle Support web page and then select your particular Kindle device after which you can follow the instructions for that device which are shown on the web page.
See the Kindle Documentation web page for further manuals
Amazon Kindle 3G | Answered on Mar 21, 2018
This is because of the wrong setting you have done. You need reset the device with default setting. Ask for the support if your issue did not resolved. Kindle Technical Support Registration 877 690 9305
Amazon Kindle 3G | Answered on Mar 20, 2018
Here is their contact info; if your in the USA. online: www.amazon.com/kindlesupport. e-mail: kindle-cs-support@amazon.com. phone: within the US: 1-866-321-8851
KINDLE FIRE CUSTOMER SUPPORT PHONE NUMBER
  • Make sure the Kindle's battery is charged. Connect to a PC using the supplied USB cable until the power LED changes colour from amber to green.
  • Slide and hold the power button until after the power LED blinks three times. If the screen now is blank, repeat the procedure
If the Kindle still does not come back to life, contact Kindle Support.
Amazon Kindle 3G | Answered on Mar 17, 2018
You can re-register your Kindle through the device itself. Go to the "Settings" menu, select "Register," and then enter your Amazon account email address and password to connect your device to your account. If you do not have an Amazon account, you are prompted to create one.
Can You Re Register After Deregistering on Kindle The Classroom Synonym
First you need to confirm that are you using the latest version of Kindle OS. If you are using the latest version then everything is ok. Or there might be the hardware compatibility issue. You can contact for the issue to the amazon kindle support Kindle Technical Support Registration 877 690 9305
Is your kindle in an unlighted cover? Amazon Kindle support suggested to me that this exact problem may be caused by interference with the metal clips that hold the kindle cover on. After taking it out of the cover, it works just fine! This does not happen with the lighted cover apparently.
They also suggested NOT turning it off when finished reading. Hit the home key and walk away. After about 10 minutes, it will power down to sleep mode on its own. Hopevthis helps.
I'm assuming you have got 'Buy with one-click' turned on then. Apart from that the thief would need your login password.
Log in to your Amazon account from another device which is connected to the Net, turn off one-click and change your password to your account.
Amazon Kindle 3G | Answered on Mar 16, 2018
This is from M. Francis Professor of Kindology on Amazons customer service forum
Standard advice for lost/stolen Kindles:
You want to deregister your device first and foremost to prevent someone from purchasing items with your account.
Immediately go to your 'Manage Your Kindle' page:
http://amazon.com/manageyourkindle
Scroll down the left-side menu and select 'Manage Your Devices'
Find the Kindle that is lost/stolen.
**BE SURE TO WRITE DOWN THE SERIAL NUMBER OF THE DEVICE, FOR FUTURE REFERENCE**
Then click 'Deregister'
** You will need that serial number when you contact Customer Support, and to identify your device from a Lost & Found, and also it will be needed if you file a police report or file an insurance claim to your homeowners or rental insurance policy.
Then, contact Customer Service and report the loss/theft. Amazon cannot help you locate your Kindle, but they will use the serial number to block the device from being registered in the future by someone else. Do this soon, because if the person who might now have your Kindle already registered it to their own Amazon account, it cannot be blocked from registering at your request any longer.
If you find your Kindle later, contact Customer Service again to reverse the process. To contact CS, click the orange 'Contact Us' button on the right side of this page, or use this link:
https://smile.amazon.com/gp/help/contact-us/kindle-help.html
Don't use the email option, but use the Phone option (if available from your location) or Chat option. By using the Phone option, after you send your phone number in, an Amazon Representative will call you back in a minute or two, sometimes sooner.
If you have Active Subscriptions:
You will also want to make sure that you cancel any active subscriptions. Canceling the subscription will ensure that you are no longer billed; you'll also receive a pro-rated refund for remaining issues you already paid for. You always have the option of subscribing at a later date.
Go to your 'Manage Your Kindle' page:
Then, scroll down the left-side menu and select 'Subscription Settings'
For each subscription you have, use the 'Actions' button to the right of the title and select 'Cancel Subscription'.
Amazon Kindle 3G | Answered on Mar 15, 2018
You can download either a PDF or AZW version of the Kindle documentation on the Kindle Support web site where it also gives guidance on how to update the same on your Kindle device.
Amazon Kindle 3G | Answered on Mar 14, 2018
If the kindle is functioning how you'd like it to, there is no requirement to update your kindle.
Amazon Kindle 3G | Answered on Mar 03, 2018
Log into your Amazon account [from a computer] and check that the account and email details are the same as those set on your kindle.
Amazon Kindle 3G | Answered on Mar 01, 2018
unfortunately, there is no screen replacement for your broken kindle 3 screen. The only option you have is to remove the screen of a dead kindle 3 that is no longer being used. To get a dead Kindle 3, you might have to visit where kindle 3 is repaired within your vicinity.
Lastly, you might end up getting another kindle 3. If there was a screen replacement for sale, it would have been much easier, but unfortunately, there isn't.
Good luck.
Amazon Kindle 3G | Answered on Feb 28, 2018
Dead Kindle I'm afraid.
Go to the main Amazon Kindle Support web page then select your model of Kindle device from the ones shown.
There is a Getting Started Guide for each Kindle model - I have given the link for the Kindle 3 3G WiFi model.
There are further guides on setting up other aspects of the Kindle including Connecting with WiFi etc.
You can easily load all of your books onto your new Kindle. Amazon retains a record of all your book purchases in an archive. When you register your new Kindle (and turn on wireless) it 'phones home' to Amazon and Amazon places an entry on your main menu entitled Archive. Just click on that entry and all of your past book purchases will appear and will automatically be downloaded to the Kindle when you click on them.
However, if your old Kindle contained any books, pictures, or documents that you did NOT purchase from Amazon, those items will not appear in the Amazon archive. You will have to download those items to your new Kindle the same way you installed them on the old Kindle. If the only location of those un-archived documents is the old Kindle, then this will become a two step process because you cannot copy from one Kindle directly to another. Instead you must copy the documents off the old Kindle onto a computer using the USB cable, and then copy the books from the computer onto the new Kindle by way of the USB cable or by email using an authorized email account. (To authorize an email account for sending books to your Kindle, please visit Amazon's "manage my devices" section. If the new Kindle is not registered, or if it is blacklisted, then you cannot use the email method to transfer the books. The only way to install books on an unregistered Kindle is directly via USB cable.)
Amazon Kindle 3G | Answered on Feb 27, 2018
Amazon Kindle 3G Logo
403 questions posted
Popular Products
Top Amazon Tablets & eReaders Experts
Norman Worley
Miguel Luiz Martins
Poul Brinchs Larsen
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Kindle Amazon
  • Kindle Amazon
Most Popular Question
kindle stolen prevent someone from
  • Tablets & eReaders
