20 Most Recent Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter Questions & Answers
Hi- not sure if it will help but I had issues getting it out. What I found is the plastic casing (fridge) needed a little twist/push. Play with it- hold the filter in and GENTLY push/pull/twist slightly the fridge housing.
Frigidaire... | Answered on Sep 29, 2019
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Frigidaire... | Answered on Aug 29, 2019
Good Afternoon Friend,
I understand that the puresource3 water filter is leaking in your Frigidaire refrigerator. Please make sure that it is the filter leaking. Check for cracks in the filter. If the filter itself is not leaking, it might be something in the filter housing that is leaking. If this is the case, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing the leak. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Mar 07, 2015
Good Morning Joseph,
I see that you are having trouble with water dispensing and ice being produced on your Frigidaire refrigerator, even after replacing water filter, model# ULTRAWF, twice. I would suggest to reset your refrigerator, by either unplugging it, or shutting the power off at the circuit breaker for at least 2-3 minutes. Once power is restored try to get water out of the dispenser. If you are still having trouble with the water dispenser, remove the water filter and replace it, making sure you hear two clicks and the filter is flush with the filter housing. If these suggestions do not work, I suggest contacting your local authorized technician for further assistance.
-Best Regards-
WP
Frigidaire... | Answered on Apr 04, 2014
The LED above the Ice Off icon should be lit when the icemaker is disabled. It should be off when you want ice from the icemaker. To toggle the setting, press and hold the Ice Off touch pad for 3+ seconds. This is shown in the manual for the FPHF2399MF2 on page 14. Sears Parts Direct has the manual here: https://www.searspartsdirect.com/manual/234cu4elin-001428/frigidaire-fphf2399mf2-bottom-mount-refrigerator .
I hope this helps.
Frigidaire... | Answered on Oct 18, 2019
If new and under warranty contact supplier. If you attempt to fix while under warranty and cause further faults then you may void warranty.
Frigidaire... | Answered on Oct 03, 2019
I would say that either the filter has split or the seal where it screws into the housing has failed. I would try a new filter and seal.
Frigidaire... | Answered on Sep 23, 2019
There are a number of reasons why this might be happening. You bets bet if to call a service guy out and let them take a look at it as some things require specialised equipment to troubleshoot.
Frigidaire... | Answered on Sep 14, 2019
possible bad water solenoid on bottom in back
Frigidaire... | Answered on Aug 22, 2019
Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter Logo
13 questions posted
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire water filter stuck
  • Refrigerators
