20 Most Recent Zenith DVB412 DVD Player Questions & Answers
The drive may have failed.
Zenith DVB412... | Answered on Dec 24, 2013
when i press play on my dvd/cd player it says error
Zenith DVB412... | Answered on Sep 11, 2013
I have the same problem! did you find a solution to this?
Zenith DVB412... | Answered on Nov 26, 2011
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Zenith DVB412... | Answered on Nov 19, 2011
Here's the LINK.
Zenith DVB412... | Answered on Aug 29, 2011
Try 0000 - It's the default code for most brands unless you set a code yourself and you've forgotten it.
If not, also try 1234, 1111, 2222, 3333, 4444, etc.
Hope this helps,
BElectric
Zenith DVB412... | Answered on Apr 09, 2011
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Zenith DVB412... | Answered on Jan 23, 2011
Here is a link to our online troubleshooting there are codes and instructions here.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Zenith DVB412... | Answered on Jan 19, 2011
I do believe you need the remote control, there is no other way that parental controls can be accessed
Zenith DVB412... | Answered on Oct 03, 2010
i need toreplacethe abs+pbt disc driver
Zenith DVB412... | Answered on Mar 21, 2010
You may need to get the discs repaired or it may be your laser in the player need cleaning. Easiest soloution is to basically clean your disc(playside). Check for scratches on both sides of your disc. If the label side is scratched in any way, it might be unrepairable as this is where the data is stored, if the playside is scratched they are repairable. You can try home remedies if the scratches are very slight, if not professional repair is required. Try other discs in your player, if they are not working either, then it may the players laser is dirty and may need a laser cleaner, fairly cheap in some stores.
If it's the disc thats scratched visit www.discREPAIR.ie for FAQs and futher help or disc repairs.
Zenith DVB412... | Answered on Mar 07, 2010
hello,
the reason the disc is jammed is because the player did not sit the disc properly.
what you will have to do is;
get a screw driver, open the dvd player, you will find a mechanism that presses the cd down to the lens, you unscrew it too and remove the disc that is jammed in it.
press open to see if it would open up, if it does, then you can screw it back together, but if it does not open then there is a fault with the mechanism that open and closes the player. so you carefully check it out and put it back in order and it would start working.
goodluck
Zenith DVB412... | Answered on Feb 04, 2010
G'Day!
It depends on the model of player you have. For example, COBY has older models that won't play anything other than commercial DVDs. However, most new DVD players, and by new I mean ones that are no more than 12 months old, can play DVD +R and -R. To find this information, you need to consult the manual or contact the manufacturer about your specific model.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Zenith DVB412... | Answered on Jul 11, 2009
Zenith DVB412 DVD Player Logo
34 questions posted
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Zenith Televison & Video
Most Popular Question
disc jammed come out
  • Televison & Video
