20 Most Recent Brother HL 1240 Printer Questions & Answers
This printer is almost 10 years old. The original drivers are for Windows 3.1, 95/98, or NT 4.0. Not sure how XP is handling it.
When you go to print and get the print window, you should be able to select Properties (or Preferences) and there should be either a Quality tab or an Advanced tab.
This is where you should be able to change the resolution to 600X600.
You are not going to get a newer driver for this because of the age, but you still should be able to get 600 DPI out of it.
Thanks for using Fixya.
Brother HL 1240... | Answered on Dec 28, 2015
Bonjour, réponse en français je suis pas bon en anglais je mettrai une traduction en anglais juste après, donc la solution est d'installer manuellement le driver de la HL 1250 de Vista cela fera fonctionner la HL 1240 mais avec les 600 dpi (pour information la 1250 est à 1200 dpi mais bridée à 600 dpi sous vista)
Vincent De Lémos (http://www.loisirsfr.com/)
Hello, response in French I am not good in English I will put a translation in English immediately following, therefore the solution is to install manuellement to drive it HL 1250 of Vista that will do to work the HL 1240 but with the 600 dpi (for information the 1250 is at 1200 dpi but bridled to 600 dpi under vista)
Hi
Turn it off and on.
Check through the paper paths and clear any paper jam.
Try disconnecting the printer.
Leave it for like 2 hours and then connect it again.
Brother HL 1240... | Answered on Feb 27, 2012
The idea to get the latest http://www.laptop-driver.net/ printer laptop drivers</a> work is normally using the xp http://laptop-driver.blogspot.com/ laptop driver
Brother HL 1240... | Answered on Oct 05, 2011
Tonner drum complaint
Brother HL 1240... | Answered on Sep 26, 2011
This printer is B/W, print only black.
Brother HL 1240... | Answered on Aug 11, 2011
Its not very hard to replace toner cartridge on your brother laser printer. please click the link below and follow the instructions with diagram, to replace toner cartridge:---- http://technoanswers.blogspot.com/2011/06/how-to-replace-toner-cartridge-on.html ----------- this should help.thanks.helpmech,
Brother HL 1240... | Answered on Jun 01, 2011
in most case this kind of issues arise if your drum is not cleaned properly with the wiper. As the printer becomes old, the wiper that cleans the drum might get reduced in size...
so it has to be checked at the first.
Brother HL 1240... | Answered on May 23, 2011
Yes if the connectors on the cable are the right type.
Brother HL 1240... | Answered on Mar 19, 2011
www.brother.com there you get the driver for your printer
Brother HL 1240... | Answered on Feb 25, 2011
Service manual: ready and alarm blinking :
Paper Jam
Clear the paper jam and press the panel button if the printer
does not automatically resume printing.
Misfeed:
Re-install the paper and press the panel button.
Clear the jammed paper inside the printer. Press the panel button
if the printer does not automatically resume printing.
check the sensors:
1) Turn off the printer power switch, open the front cover, and remove the drum unit.
2) Turn on the printer while pressing the control panel button. The Drum LED comes ON.
3) Lightly press the panel button again.
Alarm LED is ON = Front registration sensor is turned ON.
4) Press and release the panel button again.
Drum LED is ON = Paper eject sensor is turned ON.
If sensors are On, paper is being detected, Off- no paper
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Brother HL 1240... | Answered on Feb 21, 2011
If it's printing gibberish, you need to restart both printer and computer and then make sure you clear the printer cue in the computer.
Brother HL 1240... | Answered on Feb 11, 2011
From the Service manual:
Toner low: The Data and Alarm LEDs blink once every five seconds.
Toner empty: The Data and Alarm LEDs blink once every second.
Alarm & Data LEDs are ON: Toner empty
Thanks, Joe
Brother HL 1240 Printer Logo
Popular Tags
80 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
HL Brother
  • HL Brother
Most Popular Question
hl215on changing toner change toner
  • Office Equipment & Supplies
