20 Most Recent Game ON SolarPRO Pool Heater Questions & Answers
without the bypass kit you will put too much flow through the heater, and cause it to fail very quickly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Game ON SolarPRO... | Answered on Jun 11, 2014
Assuming that is either fiber glass or some sort of Acrylic tub, the best way to clean it is to drain and wipe the surface with white vinegar and then rinse with clean water.
Be sure to use a hose end filter when re-filling the tub so you will not get dirt into the tub again. Here is a link to a hose filter on Amazon.
J
/uploadswith image
Pool & Spa | Answered on Nov 05, 2019
BE EXTRA CAUTIOUS WHEN WORKING WITH ELECTRICITY. THERE MAY BE A PROBLEM WITH YOUR SPA's WIRING, CONTROLS ETC. - OR - THE
CURCUT BREAKER MAY NEED REPLACING.
DISCONNECT OTHER ITEMS THAT ARE ON THIS SAME CIRCUT [ IF ANY ] TO CONFIRM THE SPA IS THE ONLY THING INVOLVED. IF POSSIBLE, CONNECT SPA TO ANOTHER CIRCUT. UNLESS YOU ARE EXPERT AT THIS, PLEASE CALL AN ELECTRICIAN TO FAULT FIND BEYOND THESE SIMPLE CHECKS.
Pool & Spa | Answered on Nov 02, 2019
run filter and keep changing next time use filter on hose
Is the water pump delivering water to the jets? If not, then you may have an airlock. Prime the pump and check again. If you have water coming from jets but still no heat, then it may be time for a new heater section.
Pool & Spa | Answered on Oct 30, 2019
Game ON SolarPRO Pool Heater Logo
1 questions posted
Top Game ON Pool & Spa Experts
Bill Jordan
David Spradling
David Spradling
Tom Chichester
Are you a Game ON Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Game ON Pool & Spa
  • Game ON Pool & Spa
Most Popular Question
say side box solar pro xd1 heater need
  • Pool & Spa
