20 Most Recent LG MU-42PM11 47 in. EDTV-Ready Plasma Television Questions & Answers
Use the remote to switch problem,if it's not works,I am sure the power board problem
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
LG MU-42PM11 47... | Answered on Jul 06, 2017
Bad caps in power supply,Crack or splits on top of cap or leaking, Check value of caps in power supply.
LG MU-42PM11 47... | Answered on Apr 17, 2014
Hello again.
In case if you would replace fuse (it's one of two ceramic slow-burning fuses installed in holders next to each other) and it woudn't burn but TV still have no image - that means that both Z-Sus and Power Supply boards are bad. If fuse got blown again right away - usually indicates that Power Supply board still OK and does not need to be replaced.
Before go ahead and order Z-Sus board, visually check out narrow buffer board that attached to it. On other end of it you will see several flat ribbon cables that go into Plasma Panel. Make sure that you will not fined any cracked (exploded) microchips ot other electronic components or burn marks on it. Sometimes short in buffer board can cause Z-Sus short out as well. If everything looks fine - replacing just Z-Sus board would in 95% cases repair your TV.
LG MU-42PM11 47... | Answered on Sep 01, 2010
Get in touch with your cable operator and measure the strength of signals being received via the Cable. It can be boosted by the cable operator from their end or attach a booster on your line...............sodeep
LG MU-42PM11 47... | Answered on Aug 19, 2009
Your unit is in protect mode a short circuit has occured either at x,y z board.Check fuses F52 on y Board,FS1,FS2 on Zboard.Remove P1,P2,P3,P4 if power supply voltage is normal replace right x-board.Remove P6,P7 if the power supply voltage is normal replace left x-board
LG MU-42PM11 47... | Answered on Aug 01, 2009
https://www.lg.com/us/support-product/lg-55LB6100
LG Televison &... | Answered Yesterday
LG MU-42PM11 47 in. EDTV-Ready Plasma Television Logo
Popular Tags
14 questions posted
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg plasma tv sound problems certain
  • Televison & Video
