20 Most Recent LG 42PX5D 42 in. Plasma HDTV Questions & Answers
T'Con board fault. If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
LG 42PX5D 42 in.... | Answered on Nov 14, 2017
Hello... Fried devices on the y sus will usually blow the fuse on the y sus. That would explain no fizz. I hope this helps...
LG 42PX5D 42 in.... | Answered on Nov 12, 2017
a sale?
no we help ppl fix things no sales here
LG 42PX5D 42 in.... | Answered on Aug 24, 2017
go to the lock option in the menu screen, either press 0 0 0 0 or 7 7 7 7 that should unlock on lg sets anyway
LG 42PX5D 42 in.... | Answered on Jul 03, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
LG 42PX5D 42 in.... | Answered on Apr 23, 2017
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
LG 42PX5D 42 in.... | Answered on Jan 14, 2016
PRESS MENU BUTTON THEN UP / DOWN BUTTON TO SELECT SPECIAL MENU THEN TURN CHILD LOCK OFF
LG 42PX5D 42 in.... | Answered on Jan 04, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble & reassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
LG 42PX5D 42 in.... | Answered on Nov 16, 2015
This could be the main drive board failed, or the plasma display backplane has a defect. These types of repairs are generaly fairly expensive.
I would be considering to get an estimate just in case it is simple fault. But, if the repair will cost more than a few hundred dollars, I would strongly suggest a new set. Also, servicing an older set is a gamble in case something else will soon fail.
Jerry G.
LG 42PX5D 42 in.... | Answered on Jun 15, 2015
try adjusting the voltages on the panel display, the voltages are listed on the label on the panel itself. Adjusting them up or down within 10 to 15 volts should affect that speckling around the picture, if not then the panel will most likely d to be replaced
LG 42PX5D 42 in.... | Answered on Apr 14, 2015
LG 42PX5D 42 in. Plasma HDTV Logo
649 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
red speckling around border picture
  • Televison & Video
