20 Most Recent Apex Digital ADV3800 DVD Player/VCR Questions & Answers
to get sound you need to have all cables connected
Apex Digital... | Answered on Sep 14, 2014
Try 12434 12205 12084 12056 11506 11389 11354 11340 11267 10675 10646 10539 10503
hope one works for you ..
Apex Digital... | Answered on Jan 17, 2014
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Apex Digital... | Answered on May 30, 2012
Apex is a hard brand to find info or parts for--not intended to ever be repaired etc.
GOOGLE the model number of the unit for a "manual" to see if the owner manual is available online.
Apex Digital... | Answered on May 27, 2012
Hi
use red/white/Yellow cables to connect to a loose hard diskon which I keep films, TV-serials and talking books. The colour is fine.
But I connect the DVD to the TV with a scart cable.
Hope you get your colour
Kolbrun
Apex Digital... | Answered on Feb 26, 2012
Hello
First reset the device to its factory defaults and see whether it help you. If there are so many external commands we have given to the system, and it have been over the capacity of its memory, it will hang up, like our computer system do. Resettign it to its factory settings, will clear out all the memory item to factory levels, and the set will work as if is new. To reset it, come to the 'Preference page' after entering into it 'Menu', select "Default" and enter the reset option. After resetting it, switch OFF the set and switch it ON again. If this doesn't help you, the loader mechanism of the syetem is damged and should be replaced. It is a plastic made mechanism, and wont cost more.OK.
Apex Digital... | Answered on Jul 11, 2011
The unit is locked because it has detected a malfunction in the tape mechanism - most likely the tape has been pulled out of the cassette and caught so it has blocked the capstans and the drum.
To fix that you will have to take out the caught tape manually: open the case, access the tape mechanism and start taking the the tape itself out by cutting it in small pieces with a fine cutter and pulling it out gently- if the tape is wrapped around some parts do not pull on it, it might bend the parts. Once all the tape is gone assemble the unit back, power it and immediately press the Eject button on the VHS section. Once the tape cassette is out wait for 30 seconds and stop the unit, wait another 30 seconds and start it again - that should fix it.
Apex Digital... | Answered on Jun 09, 2011
  • Are you using an AV cord between your VCR and TV or a standard coax? If you are using a standard coax then first make sure the tape is functioning properly. Next try a new coax and if the problem persist there might be an issue with the coax output/input on the VCR or TV itself.
  • If you are using the AV inputs (red,white and yellow) you want to remember that the red and white are for audio and the yellow is for video. So in this case you want to
  1. Make sure the tape is functioning correct. Old tapes that have seen their better days will produce audio but no video and vice versa.
  2. Check the connection of your yellow AV input (audio). Make sure it goes from the same output on your VCR to the same input on your TV as the audio cords are running to.
  3. If this checks out then try a different audio cord and see if this fixes it.
  4. If not then try using a different output on the VCR and input on the TV all together.
  5. At this point it is possible one of the AV audio jacks are bad either on the VCR or on the TV.
Regards, Tony
Apex Digital... | Answered on Apr 22, 2011
Apex Digital ADV3800 DVD Player/VCR Logo
Popular Tags
65 questions posted
Top Apex Digital Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Apex Digital Televison & Video
Most Popular Question
code philips dvd 3680
  • Televison & Video
