20 Most Recent Toshiba MW27FN1 27 in. TV/VCR/DVD Combo Questions & Answers
That is an issue for your cable company to resolve. You rent their gear so it has to work since you are paying them good money for rental. Make them earn it.
Toshiba MW27FN1... | Answered on Aug 25, 2017
i have bpl fcr deluxe (mod. no. 18cb1) colour tv. i have prob .for search ,auto ,fine option when i go to do this it display TU-LOCK PLZ HELP ME TO FID THE FAULT.
Toshiba MW27FN1... | Answered on Oct 03, 2015
I had the same problem on a 2003 Toshiba 32A13 TV. I replaced C407, 100 uF 35V and it fixed the lines. I noticed that this capacitor was mounted near the heatsink for the vertical output IC. I don't know if the heat aged the capacitor faster or not. The only cost was $9.99 for a 32A13 service manual download. I had a new capacitor in my misc parts box and it has a 105 degrees C rating.
Toshiba MW27FN1... | Answered on Mar 29, 2015
Someone will have to take it apart---usually it is a problem with the mechanism that loads/unloads the tape or the transport mechanism that moves the tape---the latter winds the tape back into the cassette and if fails it will hang up and or mangle the tape.
Toshiba MW27FN1... | Answered on Oct 22, 2012
Hi
As the problem relates to high voltage power cord, it is to dangerous to advise anything else but to disconnect the power cord from the wall, and have the unit checked by a professional service technician. The cause may be a short circuit in the power supply board, that can only be fixed professionally.
Please do not take any risks with mains voltage.
Isaac
Toshiba MW27FN1... | Answered on Jan 31, 2011
hi friend,
i too having the same tv BPL - 21 FCR,
i have brought it from my relatives, and they lost their remote years back, and now i want to buy that remote, can u please tell me the remote model number which will be printed on your remote panel.
especially on your remote only...
plz help me, with this problem.
thank you in advance...
please send me the number to my email id
crazyabtu2000@yahoo.com
Toshiba MW27FN1... | Answered on Dec 05, 2010
You need a remote?
Toshiba MW27FN1... | Answered on Sep 01, 2010
Hi, I wonder if you have gotten the cables and Input selection right. You do not indicate what system you are using to input the Video. There are a few ways it is done, Composite Video, Component Video, and HDMI. The Cables are all used color to color jack to jack, once selected, you must then select the correct EXTERNAL Input. on the TV. You say you have Audio, but no video, you MUST first ascertain, IF your DVD is faulty, the only way to do this is to test on another TV. If you do this and on the "other" set, it is still the same, then the DVD is faulty, always try a few DVD's first too, to make sure it isn't the DVD. Now IF it is OK, you need to then ensure that you are connected up to the Video in OK, if this is all OK, and you are connected up OK, the correct External Input has been selected, and the cables, are, all correct, then unfortunately, there must be a "Fault" on the TV's external input and it will have to be taken in for a service.If so,ask for a "Quote" for the repair before proceeding. Hopefully, it will not come to that, and it is a simple cable mix up.
Toshiba MW27FN1... | Answered on Mar 31, 2010
You could possibly have an issue in the vcr portion of the set. If the vcr is not happy the set will totally shut off. These sets are so full of safety circuits that it is really hard to say exactly what it is. These are good sets so you may want to have a shop check it out for you. Thanks for using fixya.
Toshiba MW27FN1... | Answered on Dec 01, 2009
You have a problem in the vertical output circuit. Check for bad capacitors around the vertical output IC. The value of these caps are marked on the side of them. Thanks for using fixya. Please take a moment and rate this responce.
There are many sites where you can either buy an origional replacement remote or a universal. I recommend trying one of them. If no remote is working, then the IR Sensor is bad.
Remotes.com
www.replacementremotes.com
www.newremotecontrol.com
www.bizrate.com/remote-control
partstore.com
shopjimmy.com
Toshiba MW27FN1... | Answered on Oct 24, 2009
Get a small paper clip.
There should be a little hole on the DVD tray bezel or possibly around the edge. If you put the paper clip into the hole and poke around, it will partially release the tray and you should be able to gently pull the tray open.
Toshiba MW27FN1... | Answered on Oct 15, 2009
If you have a universal remote, Try looking at the manual there is a list of codes for almost every TV used. If its not there try these:0154, 1256, 0156, 1265, 0060, 1945, 1935, 1704, 1656, 1356, 1343, 1325, 1156, 0845, 0832, 0650, 0149, 0036, 1945, or 1971.
Toshiba MW27FN1... | Answered on Jul 03, 2009
There are two capacitors in the vertival output circuit that need replaced
Toshiba MW27FN1... | Answered on Apr 10, 2009
Try, 0045, 0043, 0845 or 0154, 0156, 0060
Toshiba MW27FN1... | Answered on Mar 11, 2009
Closed Caption may only come on when you have the television muted.
Toshiba MW27FN1... | Answered on Feb 01, 2009
are you formatting the dvd in the universally accepted, video mode or the incorrect VR mode?
Toshiba MW27FN1... | Answered on Jan 24, 2009
Toshiba MW27FN1 27 in. TV/VCR/DVD Combo Logo
33 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
unwanted horizontal lines
  • Televison & Video
