20 Most Recent Simbans Clearance TM 9 Inch White Android 4.0 Tablet PC 8GB, A13 1.2Ghtz Multi Touch Capacitive Screen WiFi Front Camera and G Sensor Questions & Answers
Sounds like the power button switch has given up on you. With a lot of care and time, you can fix this yourself for a few dollars if you buy the part and tools on eBay, or you can just take it to a repair shop.
Simbans Tablets... | Answered on Jun 07, 2018
swipe down from the top and check the settings in "audio profiles" See if the speaker is muted.
Simbans Tablets... | Answered on Jan 25, 2018
Your manual is here.
Turn your device on and off To turn on your device, press and hold the power key.
To turn off your device, press and hold the power key, and then tap Power off?OK.
Manuals
Simbans Tablets... | Answered on Dec 29, 2015
To reset your tablet you need to go to setting then find backup & reset and when you are there you should click on factory reset
Simbans Tablets... | Answered on Aug 18, 2015
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Tablets &... | Answered 19 hours ago
Simbans Clearance TM 9 Inch White Android 4.0 Tablet PC 8GB, A13 1.2Ghtz Multi Touch Capacitive Screen WiFi Front Camera and G Sensor Logo
1 questions posted
Top Simbans Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Ken Strite
Ken Strite
 Mikey
Mikey
Are you a Simbans Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Simbans Tablets & eReaders
Most Popular Question
user manual simbans ultimax 10 tablet
  • Tablets & eReaders
