20 Most Recent Sony BRAVIA KDL-32EX301 32" LCD TV - 16:9 - HDTV DVB-C MPEG2, DVB-T MPEG4 - 1366 x 768 - Dolby Digital Plus, Surround Sound - 4 x HDMI - USB - DLNA Certified - Media Player Questions & Answers
Tip
SELF DIAGNOSING SERVICE MODE AND POWER SUPPLY CIRCUIT
SONY KDL-32EX302 SELF DIAGNOSING SERVICE MODE AND POWER SUPPLY CIRCUIT
SELF DIAGNOSTIC SOFTWARE
The identification of errors within the AZ1-N chassis is triggered in one of two ways :- 1: Busy or 2: Device failure to respond to IIC. In the event of one of these situations arising the software will fist try to release the bus if busy (Failure to do so will report with a continuous flashing LED) and then communicate with each device in turn to establish if a device is faulty. If a device is found to be faulty the relevant device number will be displayed through the LED.
For more check the following link. Use the search tab on the top right corner to find your product .
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Apr 08, 2015 | Sony BRAVIA KDL-32EX301 32" LCD TV...
It's caused by the Bravia Sync feature. It doesn't always connect correctly. When there are issues then attempts to sync up cause the menu to appear.
The solution is to switch off Bravia Sync.
Go in to the TV's set-up menu, and choose HDMI Set-up.
Scroll down the menu list and choose Control for HDMI, then set the menu option to OFF
Let us know if that fixes the problem for you.
Sony BRAVIA... | Answered on Sep 15, 2014
hello Dear
this is panel problem please replace panel
Thanks
M Nasir
Sony BRAVIA... | Answered on Apr 14, 2019
Aron,
To perform a reset you will need to disconnect the TV completely from power for at least 30 seconds, if this doesn't resolve your problem then you may have hardware that has expired in your device. Without physically looking at your device I can't say with certainty what your problem is, it could be your PCB. There are video's online you can visit on how to test a PCB for faults.
If you are not comfortable troubleshooting your device I would suggest contacting a local electronic repair shop near you, however I will link you to a generic instructional video showing you how to perform basic troubleshooting of your device.
Hope this helps,
Best regards
https://www.youtube.com/watch?v=qxG3hmmvkJs Testing LCD TV Power Supply BoardsSTEP BY STEP
Sony BRAVIA... | Answered on Mar 08, 2019
Although I am just guessing, most Sony equipment uses metric screws. Go to a Home Depot or similar store and take the piece that you have that contains the threaded fittings and they will help you find the screws you need. https://www.manualslib.com/manual/793567/Sony-Kdl-32xbr6.html?page=7#manual This page of the manual gives some info about the screws such as not longer than 1/2" (or 12mm) to prevent damage to the set. Sony customer service may be able to supply replacement screws too.
Sony BRAVIA... | Answered on Feb 18, 2019
Go to the initial set up procedure and disable it.
Sony BRAVIA... | Answered on Feb 14, 2019
Open internal fuse or power supply failure
Sony BRAVIA... | Answered on Jan 23, 2019
Unplug from wall for 60 secounds then plug back in. See if that works.
Sony BRAVIA... | Answered on Jan 19, 2019
Press the HOME button on the remote control.
Select Settings.
Select System Settings.
Select Customer Support.
Select Factory Settings.
Select OK.
Sony BRAVIA... | Answered on Jan 18, 2019
THe antenna came of. Did you use it and is it giving troubles now? If not, then don't mind and leave it.
Sony BRAVIA... | Answered on Jan 17, 2019
Set the resolution to suit your screen.
Sony BRAVIA... | Answered on Dec 07, 2017
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sony BRAVIA... | Answered on Sep 02, 2017
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Sony BRAVIA... | Answered on Jun 25, 2017
Sony BRAVIA KDL-32EX301 32" LCD TV - 16:9 - HDTV DVB-C MPEG2, DVB-T MPEG4 - 1366 x 768 - Dolby Digital Plus, Surround Sound - 4 x HDMI - USB - DLNA Certified - Media Player Logo
2 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
BRAVIA Sony
  • BRAVIA Sony
Most Popular Question
bravia menu comes up across screen will
  • Televison & Video
