20 Most Recent Maytag MVW18PDAWW MVW18PDAWW Commercial Energy Advantage Top Load Washer with Microprocessor Controls and Coin Drop-Ready in White Questions & Answers
inside agitator 7/16 bolt remove and lift out and plate
Maytag Washing... | Answered on Oct 10, 2019
check to see if drained or spinned out
remove agitator and replace plastic piece with screws to bottom probably stripped gears only about 14 dollars on amazon
It is not that hard of a job, You have picked a topic that is rare for this machine though. Fill issues are not common. Anyway you need to unplug it and turn off the water supply and disconnect the hoses, Check for hinges on the back of the unit that connect the lid to the back. The top section usually lifts from the front edge and you may need some plastic wedge to avoid paint damage while separating. When you lift it, you will see the valve assembly and you just remove the hoses that are clamped to them and then remove the wire connections and then the mounting screws. You put the new in and install it in reverse. Take pics with a digital or camera phone if you think it is going to be confusing. That way you can get itt back the way it was.
Maytag Washing... | Answered on Oct 04, 2019
Turn off the deep clean and extra rinse cycle options.
Maytag Washing... | Answered on Oct 02, 2019
Maytag MVW18PDAWW MVW18PDAWW Commercial Energy Advantage Top Load Washer with Microprocessor Controls and Coin Drop-Ready in White Logo
0 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
maytag 2000 series shows error code f6
  • Washing Machines
