20 Most Recent Apple iPhone 6 Questions & Answers
They are special screws and drivers get them on ebay 5 bucks or so
Apple iPhone 6 | Answered on Oct 11, 2019
Hello Jabob. If your iPhone 6 is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPhone unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Apple iPhone 6 | Answered on Sep 18, 2019
use the usb cable provided do not turn camera on when you plug it in to the usb port and it should automatically open to the camera photos or blue tooth them to pc
Apple iPhone 6 | Answered on Sep 17, 2019
If you forgot passcode on iPhone, there are several ways to reset your iPhone passcode. Just follow below steps to do that.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Apple iPhone 6 | Answered on Aug 22, 2019
To know if the phone is working, turn the ringer switch on & off. You should feel the phone vibrate.
It could be a battery issue too? Does the screen bulge up a bit in the center? If yes the battery needs relaplacing ASAP if not sooner, otherwise it will break the screen & possibly stuff the phone as well if battery leaks into the phone
Apple iPhone 6 | Answered on Aug 19, 2019
its not recondmended its a screen /lens not like regular glass where you can buff out fine scratch with toothpaste the following links show how to remove scuffs or very very fine scratches but on some creens trying to remove a scratch may cause malufunctions
I5 Phone Screen Scratch Remover Yahoo Video Search Results http://mashable.com/2014/06/28/phone-screen-scratches/#8C596Bi36aqt How To Clean and Remove Scratches on the iPhone 5 5S 6 6 Plus
There are a few ways to unlock passcode when you forgot the passcode. You can follow below steps to reach this aim.
If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
Apple iPhone 6 | Answered on Jul 26, 2019
There are different reasons for messages out of order. However, you also can try some ways to fix this issue. I will show one of them.
It is also a good idea to set the "Date & Time" to address iPhone text messages out of order issue. This method only calls for moving to "Settings> General> Date & Time" to turn off the option of "Set Automatically" and enabling this option in a few seconds.
Thus, you can check whether iPhone messages are still out of order. If this does not work for you, you can continue to try the next way.
set-date-and-time-4-nze4mpwo11clyawmyquav5nl-5-0.jpg For more methods, check: Fixed: Text Messages Out of Order on iPhone
In your Photos app on iPhone, you can select some photos and share to your gmail directly. It's very simple. If you need to know the detailed steps, check this tutorial: 5 Ways to Transfer Pictures from iPhone to Laptop
If you plan on doing it yourself, eBay and Amazon are good options for buying a new screen. Use the search keywords "iphone 6 screen replacement". I did, and found 1,903 listings on eBay for an average of $70 each. Watch the sellers' ratings, and I personally look for sellers that have sold a large number of the item I want. If you need the tools to do this, look for sellers offering tools included with the screen (package deal), as it makes the job much easier.
Just remember the 'Golden Rule' of electronics: Go slow and take your time! Double check your connections, and don't rush.
Apple iPhone 6 | Answered on Jul 24, 2019
there are so many tools for phone unlocking one of the best tool is https://www.unlockninja.com Unlock Your Cellphone Use Any Network in The World
Apple iPhone 6 | Answered on Jun 20, 2019
When your iPhone is locked by the iCloud activation, you may get worried. However, there are some programs can help you to unlock iCloud.
1. iCloud Bypass Tool
This software is quite popular and simple to make use of, which is quite helpful when you want to unlock iCloud for free. It can be applied to all iOS versions and Apple models in the market. However, you should know that the rating of it is just 3.5 stars and its download speed is not so pleasant.
top-5-iphone-icloud-unlock-free-software-2019icloud-bypass-tool-1-jdpz3letj1gzntsicq43yvw2-1-0.jpg 2. LockWiper
iMyFone LockWiper is very powerful with various functions and features, which can remove iCloud account quickly and conveniently. It calls for no password of your iCloud. This efficient tool will allow you to feel relaxed to unlock iCloud on iPhone. You can finish the unlock process by yourself with a few clicks after you connect iPhone with computer. After the removal is successful, you will be able to access your iPhone iCloud account smoothly.
top-5-iphone-icloud-unlock-free-software-2019lockwiper-21-jdpz3letj1gzntsicq43yvw2-1-2.jpg For more methods, check: Top 5 iPhone X/8/7/6/5/4 iCloud Unlock Free Software 2019
Apple iPhone 6 | Answered on Jun 19, 2019
If your iPhone can be recognized by iTunes, the recovery will be much easier for you. Besides iTunes, if you only want to recover photos from broken iPhone only and save them on computer, there are also several methods available for you. Download Leawo iOS Data Recovery ' Leawo iOS Data Recovery for Mac and install it.
Step 1: Choose Recover from iOS Device
Run Leawo iOS Data Recovery and choose Recover from iOS Device.
Step 2: Click Start Button
Connect iPhone to computer with USB cable. Then click the Start button.
Step 3: Select iPhone Photos
The program scans your iPhone. Check Camera Roll when the scan finishes, and select the photos you need. Then click Recover.
Step 4: Choose Target
Click Open in the pop-up dialog to choose a target folder on your computer. Then click Go to start recovering photos from broken iPhone.
recover-from-ios-contacts-hraoc4bd1cy3f24n2aesny2m-3-0_1.jpg For more detail, check: How to Recover Photos from Broken iPhone
Apple iPhone 6 | Answered on Feb 01, 2019
I also faced a similar problem and then I took my phone to a local iPhone repairing center in Bangalore
You can check them out too, if you are from Bangalore.
Apple iPhone 6 | Answered on Nov 14, 2018
You can directly delete books from your iPhone in the iBooks app. Here is how:
Step 1. Find and open the iBooks app on your iPhone.
Step 2. Click on My Books at the bottom bar. Click on Select on the right hand corner, tap on the books you want to remove.
Step 3. Click the red Delete button to remove books in iBooks from iPhone.
Apple iPhone 6 | Answered on Sep 05, 2018
First, download the iTunes and backup all the data of your phone.
Then, go to the official website and download the data recovery software. It is likely call Frombyte Recovery For IPHONE.
Next, scan file you need by the data recovery software.
After scanning, you can recover your deleted messages.
Apple iPhone 6 | Answered on Jul 10, 2018
On your iPhone, go to Settings, then General. Tap on Reset. You should see three different options to choose from.
To proceed, tap on Reset All Settings. Be careful not to tap 'Erase All Content and Settings'
Your iPhone's settings should be back to its original configuration without you having to lose all your data and restore them at a later time.
Apple iPhone 6 | Answered on May 30, 2018
Great resource for how to delete texts here with pictures.
How to Delete Text Messages From an iPhone
Apple iPhone 6 | Answered on Dec 15, 2017
Tip
How To Unlock iPhone 6
How to unlock iPhone 6
Here is the step by step process to Unlock iPhone 6
How to unlock iPhone Factory Unlock iPhone
on Nov 22, 2017 | Apple iPhone 6
Apple iPhone 6 Logo
202 questions posted
Popular Products
Top Apple Cell Phones Experts
Ekse
jacobcheatha
Level 1 Expert
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
activate new apple 6s iphone
  • Cell Phones
