20 Most Recent Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Questions & Answers
I had the same problem...turned out it wasnt the TV at all. It was actually the wall socket. Seems I had to many things plugged into one wall supply. (i.e. xbox 360, wii, audio reciever, dvd player, vcr, etc...) after switching some other items to a different socket my TV works GREAT!! I hope your problem is this simple!
Westinghouse... | Answered on Jun 02, 2019
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Westinghouse... | Answered on May 09, 2019
The power supply could be failing.
Westinghouse... | Answered on Jan 14, 2018
They will not work with NZ (NZ uses PAL-B)system directly, you may find a PAL-B to NTSC TV system convert box to make them work. (Only through Ant. or composite input).
Westinghouse... | Answered on Oct 28, 2017
The TV power supply could be failing.
Westinghouse... | Answered on Aug 29, 2017
0000 is default password till you change it
Westinghouse... | Answered on Nov 21, 2016
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Westinghouse... | Answered on May 29, 2016
T con board or the LCD panel is faulty.
http://electro-medical.blogspot.com/
Westinghouse... | Answered on Apr 26, 2016
Yes if in the settings menu, check in menu and look for format or wide usually in settings. If you do not see this than no may only be on the remote, but u can buy a universal like a 3 function RCA remote and look on the remote for the button format, wide, or a outline of a picture and program to the tv and it should do it for u. Hope this helps, thanks.
Westinghouse... | Answered on May 06, 2015
its ok, pause the screen and get a wax crayon the colour that you want the peoples faces to be and colour over them on the screen. when you have fully enjoyed that frame scrub it off and pause the video 1 second later. eventually you will make the whole movie like this the exact colour you want it.................
Westinghouse... | Answered on Mar 30, 2015
Hi, bad speakers in many flat panel TVs is a common problem. There will be av out sockets at the back of your tv. Please connect the audio from here to any amplifier or any music system you have. If you get the tv programme sound, most probably the speakers are bad. In case you do not get sound, your tv is not producing it. If the speakers are bad and you can change yourself, give it a try. Otherwise show the set to someone qualified to repair it.
Westinghouse... | Answered on Feb 24, 2015
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Westinghouse... | Answered on Oct 06, 2014
Refer its user manual for details. How to set it the color to its default settings, is described by it. Try a reset too.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Westinghouse... | Answered on Sep 16, 2014
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Westinghouse... | Answered on Sep 15, 2014
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
587 questions posted
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Televison & Video
Most Popular Question
screw holes back tv
  • Televison & Video
