20 Most Recent Philips Magnavox Learning Universal Remote Questions & Answers
Download just the Philips Codes booklet for the Philips SRU3004WM/17 here. I have included the full codes booklet in a PDF format.
Your welcome. Make sure you Thumbs up me!
Philips Magnavox... | Answered on Oct 11, 2019
Just reconfigure a remote control.
This website has many kinds of tv remotes
https://www.abctay.com/tv-remote-controls-c-66_4
Philips Magnavox... | Answered on Sep 05, 2018
It sounds like you have a problem with your 'main board'. It's board where all the outside connections come in or as we used to call it the 'tuner board'
Gillight
Try spraying tuner cleaner down beside the button. Be sure you get a good turner cleaner like Chemtronics. If that doesn't work you will have to disassemble the remote and check the membrane under the buttons. If the button is used a lot it may be torn or wore out.
Gillight
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
Philips Magnavox... | Answered on May 06, 2018
press and hold Tv VCR or DVD wait until the red light turns on then press power. Now press channel up or down until the the device turns on if you press it again while the device is on you'll have to do it again. After that hit OK then test it by pressing the volume button
Philips Magnavox... | Answered on Feb 02, 2018
You can go here to see if you can get a new factory remote
TV Parts Universal TV Stands DLP Chips ShopJimmy or you can get a Harmony remote that will never go obsolete no matter how many times you change Tv's in the future or add components to your system
Philips Magnavox... | Answered on Oct 12, 2017
Try using code search.
Philips Magnavox... | Answered on Sep 22, 2017
There may be a way to get to the audio and video without a remote by first pressing the menu button on the front of the set (if there is one), but the easiest fix is to invest in a good universal remote which will allow you to open the full TV menu. From the start up menu the remote will, after matching the code, allow you to go deeper into the start up menu to the audio/video menu and on to the "regular TV mode".
Philips Magnavox... | Answered on Jul 28, 2017
An applicable code would be in the remote, if compatible. You can use code search to find out. If a search through all codes stored in the remote fails, you my have to try a different universal remote. All universal remotes do not contain all possible codes.
Philips Magnavox... | Answered on Mar 18, 2017
I have the vivid universal remote vrc4000 users manual
Philips Magnavox... | Answered on Oct 05, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Philips Magnavox... | Answered on Sep 22, 2016
Philips Magnavox Learning Universal Remote Logo
976 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
srp2006 27 universal remote codes lg tv
  • Televison & Video
