20 Most Recent Olympus Camedia C-840L Digital Camera Questions & Answers
this means that your memory card is almost full...
Olympus Camedia... | Answered on Nov 28, 2008
Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Make sure your rechargeable batteries are all good. One defect in a set is killing for the whole set
Don't use barrettes from different sets or brands together.
I had one brand good NiMH batteries and a very expensive charger from the same brand. The charger destroyed all my rechargeable (more than 60 now). When I first discovered the batteries were dropping out, I stopped using the charger, but it did not prevent all batteries to die in the following months. Every time on dropped out I had to change the set. I tried using up the others by grouping the ones with the same Ri, but not longer then a few months and I had a box full to trow away.
Never use a quick charger, capable of charging them within an hour or faster. Us a charger that indicates the Ri is still low enough, so you can see what batteries are bad.
Check you are using a charger for NiMH batteries.
I would try another set (new) because buying Alkaline is also not cheap.
I used 2700 mAh and later 2600 mAh rechargeable, all dead now. since a few weeks I'm now using 2300 mHh from another brand, costing 1/5 of the "best" I had before, and they are doing great. I won't charge them with the quick charger.
Never use manganese (Zinc-Carbon) batteries in electronic devices.
These batteries are only to be used in flash lights.
Olympus Camedia... | Answered on Dec 07, 2016
This 14 year old camera, does not have a zoom lens. It has a 5,5 mm lens, giving it a angle of view of about a 35 mm lens of a Full frame camera. However, you should be able to zoom digital 2 times.
I can't find a manual, to help you on this, but the quality will be the same as cropping into a frame on your computer. So if you do put the pictures on a computer, you also can "zoom" in to the parts you want. Be aware a 1 megapixel camera, does not offer that much of detail.
Olympus Camedia... | Answered on Oct 27, 2014
Lens is out of possition and stuck.
Olympus Camedia... | Answered on Jul 31, 2014
Put memory card into camera right way around.
Olympus Camedia... | Answered on Jul 05, 2014
Hi, any error messages?
Olympus Camedia... | Answered on Jun 20, 2014
Like many point&shoot cameras, the SZ-12 does not have manual focus. The closest you can come is to point the camera at the object your want in focus, press the shutter release button halfway, then frame the photo the way you want it and press the shutter release button the rest of the way.
Olympus Camedia... | Answered on Dec 16, 2013
What model Olympus camera?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (http://picasa.google.com).
Olympus Camedia... | Answered on Nov 23, 2013
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Olympus Camedia... | Answered on Nov 22, 2013
To be sure your camera can connect to the PC. if it does, download a photo recovery software called hodo photo recovery which help me before. you can recover your photos by it.
Olympus Camedia... | Answered on Aug 07, 2013
It doesn't matter to the camera how your computer is set up. In fact you can use the camera without having a computer at all.
If you're asking about how to set up the computer so you can download photos from the camera, the best way involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Olympus Camedia... | Answered on Apr 20, 2013
Olympus Camedia C-840L Digital Camera Logo
5 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Camedia Olympus
  • Camedia Olympus
Most Popular Question
vista versus olympus camedia c 840l
  • Cameras
