20 Most Recent Philips 21PT4475 TV Questions & Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Philips 21PT4475... | Answered on Jul 12, 2017
wepu, Buddy it sounds like you got a power supply problem. As you say the picture is all blue?? With no video or sound and the fact that the channel display is out is the first indication that i would guess this. Do you still have the owners manual that you got when you first got the set? Good, cause thats the only place i can think of where to look in case of service over in your part of the world as I did try!! Man I tryed but to no avail. No one has heard of this model but that dosent mean that it dos'ent exsit!.. If your a tech or know your way around solid state circuitry then you should have no problem finding the fault once you get a service manual from the service location in your owners manual. Now if your not a tech and a handy man ?? If I were you I wouldnt mess with the tv as theres over 25000 volts inside the set and i've seen it make a grown man cry. Man dont attempt the repair or troubleshooting if you dont have the right or proper tools and equipment!!! Good Luck
Philips 21PT4475... | Answered on Nov 08, 2013
Usually with these types of TVs the fuse is located on a circuit board inside, often right next to where the power cord enters through the plastic case of the tv. If you are not familiar with electronics, I would not recommend replacing the fuse yourself, for safety reasons. See if you can get a professional to do it for you, or at least a friend that is familiar with electronic devices. Good luck! Der Strom
Philips 21PT4475... | Answered on Sep 27, 2010
Try to resolder or check for cold solder on PC boards..if not, for your safety you have to consult it with electronic serviceman certified..
Philips 21PT4475... | Answered on Sep 11, 2010
try search in google.com
check the H-out transistor..or the B+
Have you check the power cable connection the check the fuse
try using remote control
try hard reset unplug for hrs
Philips 21PT4475... | Answered on Jun 24, 2010
Hi haydenjessa6,
Instead of toothpaste (although it will leave TV set minty fresh) go to your local glass shop. You know the place; where they replace windshields and sell windows and mirrors. They will have a powder polish that you can use and might only charge you a small fee for a small amount. You might find it at a local jeweler as well. Ask for "jewelers rouge" or "polishing rouge". Mix it one part to one part water and one part glycerin and use the polishing wheel on a roto-tool (Dremel).
Another product to try is an automotive polishing compound such as Dupont 7.
Of course all of this is assuming that this is a glass screen and not a plastic screen on a projection TV. Remember that if the scratch is too deep no amount of polishing will remove it...
Good luck,
Rob
Philips 21PT4475... | Answered on Apr 21, 2010
Yes,Try website 1-800-remotes Factory original.To buy an exact remote.
Philips 21PT4475... | Answered on Mar 17, 2010
Check the supply voltage for the IC sound or change the IC.
Philips 21PT4475... | Answered on Jan 08, 2010
should be 1 of these codes :
0060 0579 0035 0036
0346 0577 0214 0066
0110 0216 0366 0397
hope this helps :)
Philips 21PT4475... | Answered on Oct 15, 2009
Philips 21PT4475 TV Logo
35 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
want service diagram philips 21pt240b 94
  • Televison & Video
