20 Most Recent Fuji FinePix A330 Digital Camera Questions & Answers
Sir,
This answer is regarding Fuji Finepix A330 pictures have horizontal lines this indicates camera is working fine but LCD screen is damaged.Kindly replace in nearest camera service center.
Fuji FinePix... | Answered on Feb 04, 2018
Try googling fo r the info...they have a huge range of details for just this sort of problem. If not, tryto access memory operation thtough your unit's memory - there should be a trigger giving initialization details. Hope this helps!
Fuji FinePix... | Answered on Jan 12, 2018
"initialize" means to format the card in the camera. This will erase it so download any pics first using a card reader if necessary. Then, with the card in the camera, go into the menu and find "format" or "initialize" and follow the on-screen instructions.
Fuji FinePix... | Answered on Sep 13, 2015
reset the factory settings...and replace the cells.....sud be wrking fyn after resetting to default factory settings..
Fuji FinePix... | Answered on Mar 24, 2015
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Fuji FinePix... | Answered on Nov 19, 2014
perhaps you fine help on ifixit.com. There they take apart lots of camera's and show the video or even a manual. They also help with buying spar parts and tools if you need some.
Success
Fuji FinePix... | Answered on Jul 20, 2014
You should try photo recovery software to rescue the photos on your card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
Fuji FinePix... | Answered on Nov 06, 2013
How long you have the battery? I suggest you to fully discharged the battery and then charge it as much as you can, do this circle for several times. Hope this can help
Fuji FinePix... | Answered on Oct 09, 2013
The FinePix A330 works with xD Picture Cards, not with SDHC cards.
Fuji FinePix... | Answered on Apr 22, 2013
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Fuji FinePix... | Answered on Dec 30, 2012
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
You don't need any special software.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
You may download a copy of the manual here.
The date/time command is in the setup menu. See the "Set-Up" section beginning on page 48 of this manual.
Fuji FinePix A330 Digital Camera Logo
191 questions posted
Top Fuji Cameras Experts
Ekse
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
purchased 8gb fijifilm card a330 39 t
  • Cameras
