20 Most Recent Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Questions & Answers
Blue blotches spreading over the screen are failure of the optical block
contact Sony to see if you are eligable for a free repair.
Sony will cover the cost of the optical block repair (parts and labor) at no charge through December 31, 2008 for 2004 Model Year Grand WEGA™ Televisions with the blue spot problem.
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
http://esupport.sony.com/US/perl/news-item.pl?news_id=
Read more: Help from Sony for LCD rear projection with blue spots - Home Theater Forum - Home Theater Systems - HomeTheaterShack.com http://www.hometheatershack.com/forums/sony/5351-help-sony-lcd-rear-projection-blue-spots.html#ixzz0gm8a3718
Don't bedeterred by the dating of this announcement, it is a manufacturing fault and they have been pr5etty good to a lot of people with the same problem.
Please rate my help++++Thanks for using FIXYA
Sony Grand WEGA... | Answered on Nov 30, 2018
hi if you've fitted a new lamp, make sure the lamp door is securely fitted, and clear the lamp counter thanks
shaun
Sony Grand WEGA... | Answered on Mar 03, 2018
Power supply capacitors, try taking a hair dryer and put it on the vents in the back and see if it will come on after warming it up for 3 or 4 mins, if it does its capacitors, you can replace them yourself if you can solder or replace the power board.
Sony Grand WEGA... | Answered on Jan 08, 2018
Probable power supply failure
Sony Grand WEGA... | Answered on Sep 09, 2017
Sounds like a CCD imager issue to me. Talk nicely to Sony, not the sales shop and you may be a happy customer again.
Sony Grand WEGA... | Answered on Aug 08, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony Grand WEGA... | Answered on Apr 01, 2017
Hi Fkanode.
The failure(s) in your TV is related to a part called light engine or optical block and Sony TVs are known for these kind of failures with the video showing with different colors or lines.
Check the link provide for more info or if you would like to try fixing the TV yourself.
Let me know if you would need further assistance.
Sony Grand WEGA... | Answered on Mar 07, 2017
follow the power cord and just check the input fuse if you've got a surge protector on it it may have just blown the fuse from a spike. It doesn't hurt to try. This fuse is inside the tv.
Sony Grand WEGA... | Answered on Jan 04, 2017
Did you get the correct lamp? 5 blinks (if I remember correct) is a lamp issue.
Sony Grand WEGA... | Answered on Jun 23, 2016
You need new optic block. Sony will pay for repair if you contact an authorized SONY repair facility
Sony Grand WEGA... | Answered on Mar 17, 2015
sounds like a convergence problem. If this set has magic focus, use it.
Sony Grand WEGA... | Answered on Dec 08, 2014
at the back you will see a dvi port .you can use this to connect to your pc but you need advi cable
Sony Grand WEGA... | Answered on Oct 13, 2014
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
773 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony restarts frequently
  • Televison & Video
