20 Most Recent Sony FD Trinitron WEGA KV-32FS120 32" TV Questions & Answers
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
Sony FD... | Answered on Jun 24, 2018
Failing power supply
Sony FD... | Answered on Feb 24, 2018
I have a sinotec 32" LCD TV.when i put my tv on its shows me LCD TV in the center of my tv. and ofter screen is black
Sony FD... | Answered on Jun 26, 2017
Ensure the set top box is set to the correct video out. Probably RGB if scart lead or CVBS if coax lead.
Sony FD... | Answered on Jun 10, 2017
A specific model number will probably get you more specific
help.. but if you check around the internet by model number
you will likely be presented with some SERIOUS PART opportunities...
The FASHING LIGHT means you have a hard fault in the power circuits...
The number of flashes is mean to point you to a specific area...
I gave all my big flat screens away in favor of the new
HD stuff... (certainly less reliable than those Sony sers...
Shopjimmy might be a great place to call... but the MODEL NUMBER is a MUST.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sony FD... | Answered on May 18, 2017
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sony FD... | Answered on Apr 12, 2017
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Sony FD... | Answered on Apr 08, 2017
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Sony FD... | Answered on Apr 07, 2017
It's going in to protect mode check power supply fix the caps it's overheating
Sony FD... | Answered on Apr 05, 2017
Hi Simonbra,
According to the service manual. the 5 blinks is due to a defective IC on the M board, The defective part is IC001
I can send you the service manual if need be.
Sony FD... | Answered on Mar 02, 2017
Probably a defective horizontal output transformer , also check the horizontal output transistor. Both parts available from tritronicsinc.com
Sony FD... | Answered on Jun 25, 2016
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
1,778 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
tv works vcr dut when sattelite box
  • Televison & Video
